P0344 – Camshaft position (CMP) sensor A, bank 1 circuit intermittent
Last Updated 2016-08-22
P0344 | Camshaft position (CMP) sensor A, bank 1 circuit intermittent | Wiring, poor connection, CMP sensor, ECM |
What Does Code P0344 Mean?
The camshaft position sensor reacts to a toothed wheel on the camshaft, which gives the ECU constant information on its speed and position. Of course, the CMP is located on the engine, usually somewhere on the cylinder head, so it transmits CMP data to the ECU using wires. If the ECU intermittently detects a CMP signal, it will set DTC P0344 or DTC P0349 – Camshaft Position Sensor Circuit Malfunction. If your engine has only one CMP, such as an inline-four-cylinder, the only CMP code available is for Bank 1, P0344. On the other hand, V6 or V8 engines have two banks, Bank 1 and Bank 2, and would therefore have two CMPs, so DTC P0349 would refer to Bank 2. Sensor A indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the intake camshaft. Sensor B codes pertain to the exhaust camshaft.
What are the common causes of code P0344 ?
Depending on year, make, and model, DTC P0344 or P0349 may have number of causes. Here are some of the most common.
Ford Trucks / Mustang GT – An alternator phase problem, such as a blown diode or open coil, may cause so much electrical interference that the CMP signal gets distorted, causing a P0344 / P0349 DTC to set, among others, in spite of there being no actual problem with the CMP sensor or wiring.
What are the symptoms of code P0344 ?
How do you troubleshoot code P0344 ?
Because P0344 and P0349 refer to a circuit problem, do not automatically condemn the CMP sensor. That’s not to say that it might not be the sensor itself, but replacing the sensor is not always going to fix the problem. Get out your wiring diagram and DVOM (digital volt-ohm meter) for this next part.
- Sensor Inspection
- Other Problems – In case no problems can be found in the CMP sensor or its wiring, it may be that P0344 or P0349 are simply auxiliary fault codes. A jumped timing belt, faulty crankshaft position sensor signal or circuit, or engine misfire, may be the primary problem. Double check these before coming back to the CMP.
Codes Related to P0344
DTC P0344 or P0349 may be accompanied by other DTCs, such as P0300 Random Misfire, P0725 Engine Speed Sensor Circuit, or P0335 Crankshaft Position Sensor Circuit Malfunction.
BAT Team Discussions for P0344
- 2003 durango sxt with 4.7L; hard start, 3500 rpm rev limiter, no cruise control
[b]Re: 2003 durango sxt with 4.7L; hard start, 3500 rpm rev limiter, no cruise cont[/b] here are the codes.... p0440 p0344 p0340 p0440 p0340 the last 2 came up 2 times....... it says 5 codes...... - 2002 Intrepid p0344
I have a 2002 Intrepid with the 2.7 engine. It has 65000 miles. Back when it had 25000 or so miles on it, when I hit a bump the check engine light came on and it wouldn't run right. It was under warranty so I took it back and they replaced the cam sensor. Intermittently since the warranty expire... - 2005 sebring touring starting problem
First thoughts- are you sure this engine (electronics) 03 is compatable with 2005? are there any other codes other than p0344?- you got the code- wondering do you have a scanner? code is for intermittant- move shake harness while checking ground and 5v referance. Can't think of an easy... - 2006 Jeep severe miss at 2,400 RPM
The P0431 code is still staying away. I'm pretty sure that the cats needed replaced. My engine code that comes on after the bucking starts is p0344. I've had that code on other rigs from bad spark plugs but, like you said, cause or effect hasn't been determined. I'll keep watching those. My s...
just bought a 2005 dodge neon sxt. had it one day and as i was entering the freeway felt slight hesitation then, nothing. In Approx. 1/4 mile it started spluttering and hesitating. Engine light came on. Feeling like it was not getting air.Or even a fuel pump. Starts, Idles great. Now driving at 25-30mph it will lose power spluttering/ Hesitating.. sometimes it will stop after pulling over a few minutes and be fine, then stat again once accelerating.. checked spark plugs, wires,fuses, unplugged/ plugged connections within.. after reading about the CMP, cam sensor. i know will try my best..
thank you for all your input and i hope to learn more from you in the future with this car…
Robert-
Forgive the delay, please. Judging by what you’ve mentioned, I would guess that you have a loose connection somewhere, though it might not be right at the sensor. One way to find this problem is to disconnect the ECM and CMP and put a jumper wire across the CMP connector. With the multimeter set to check continuity, you should have continuity when testing from the ECM side. Then, with the continuity tone sounding, follow the harness from the ECM to the CMP, wiggling and twisting it as you go. Chances are good you’ll find a break somewhere in the wiring. (Some aftermarket remote starters also tap into engine sensors to see engine rpm, which screws things up sometimes.)
Buenas tengo una grand cherokee 2007 motor 4.7 4×4 límites soy de venezuela tengo problema con ella me aparece los códigos p0300 y ahora el p0344 este último apareció nuevo sólo tenía el p0300 y e revisado todas las entradas de aire y no e podido quitar ese código y mi camioneta queda inestable con respecto al ralentí y con el código p0344 no acelera al darle más aceleración la camioneta de queda no avanza y corcovea como.un caballo saludos
Buenos dias, tengo una peugeot partner 1.6 2015 con el codigo p0344, no arranca.andaba y se puso lento bajo en rpm y luego de apagarlo no encendio mas! Ayuda!
