P0342 – Camshaft position (CMP) sensor A, bank 1 -low input
Last Updated 2016-08-22
P0342 | Camshaft position (CMP) sensor A, bank 1 -low input (Buy Part On Amazon) | Wiring short to earth, CMP sensor, ECM |
What Does Code P0342 Mean?
The camshaft position sensor reacts to a toothed wheel on the camshaft, which gives the ECU constant information on its speed and position. Of course, the CMP is located on the engine, usually somewhere on the cylinder head, so it transmits CMP data to the ECU using wires. If the ECU detects a low resistance (short circuit), it will set DTC P0342 or DTC P0347 – Camshaft Position Sensor Low Input. If your engine has only one CMP, such as an inline-four-cylinder, the only CMP code available is for Bank 1, P0342. On the other hand, V6 or V8 engines have two banks, Bank 1 and Bank 2, and would therefore have two CMPs, so DTC P0347 would refer to Bank 2. Sensor A indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the intake camshaft. Sensor B codes pertain to the exhaust camshaft.
What are the common causes of code P0342 ?
Depending on year, make, and model, DTC P0342 or P0347 may have number of causes. Here are some of the most common.
Ford Trucks / Mustang GT – An alternator phase problem, such as a blown diode or open coil, may cause so much electrical interference that the CMP signal gets distorted, causing a P0342 / P0347 DTC to set, among others, in spite of there being no actual problem with the CMP sensor or wiring.
What are the symptoms of code P0342 ?
How do you troubleshoot code P0342 ?
Because P0342 and P0347 refer to a circuit problem, do not automatically condemn the CMP sensor. That’s not to say that it might not be the sensor itself, but replacing the sensor is not always going to fix the problem. Get out your wiring diagram and DVOM (digital volt-ohm meter) for this next part.
- Sensor Inspection
- Other Problems – In case no problems can be found in the CMP sensor or its wiring, it may be that P0342 or P0347 are simply auxiliary fault codes. A jumped timing belt, faulty crankshaft position sensor signal or circuit, or engine misfire, may be the primary problem. Double check these before coming back to the CMP.
Codes Related to P0342
DTC P0342 or P0347 may be accompanied by other DTCs, such as P0300 Random Misfire, P0725 Engine Speed Sensor Circuit, or P0335 Crankshaft Position Sensor Circuit Malfunction.
Hi all Wish every one here is ok I am a little bit confused, what actually difference between Stored and pending codes. I own a chevy Optra/Lacetti 1.6L model 2008 , month ago I got a MIL indicating that the CAMSHAFT P0342 and i changed the senor and nothing were read again. Now when i diagnostic the car using MD802 ALL i found this code came again in pending code, I deleted the code several times and when check again after 2 days, the code appear again without MIL and as a pending code again.!!!! what is the hell of that please could any one explain it plz. Thanks in advance
Many thanks for these info
The resistance check is not so clear in how to do it especially the part say An open-circuit, ∞ Ω, or short-circuit, 0 Ω,
Richard-
Usually, these sensors are two-wire sensors, so if you disconnect it, you can use your DMM to measure resistance across the two terminals. (Three-wire sensors you need to check for power and ground, but the signal may be impossible to read without a scan tool or scope.) The actual resistance specification depends on the vehicle. What I was trying to get across was that, if you read infinite resistance (open circuit) or zero resistance (short circuit), then you can judge the sensor to be faulty. On your DMM, a short circuit would show up as 0.0 Ω and an open circuit might show up as ∞ Ω or OL (over limit). I’m sorry for any confusion, but does this help at all?
