P0341 – Camshaft position (CMP) sensor A, bank 1 range/performance problem
Last Updated 2016-08-22
P0341 | Camshaft position (CMP) sensor A, bank 1 range/performance problem | Insecure sensor/rotor, air gap, wiring, CMP sensor |
What Does Code P0341 Mean?
The camshaft position sensor reacts to a toothed wheel on the camshaft, which gives the ECU constant information on its speed and position. Of course, the CMP is located on the engine, usually somewhere on the cylinder head, so it transmits CMP data to the ECU using wires. If the ECU detects a range / performance problem with the CMP signal, it will set DTC P0341 or DTC P0346 – Camshaft Position Sensor Circuit Malfunction. If your engine has only one CMP, such as an inline-four-cylinder, the only CMP code available is for Bank 1, P0341. On the other hand, V6 or V8 engines have two banks, Bank 1 and Bank 2, and would therefore have two CMPs, so DTC P0346 would refer to Bank 2. Sensor A indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the intake camshaft. Sensor B codes pertain to the exhaust camshaft.
What are the common causes of code P0341 ?
Depending on year, make, and model, DTC P0341 or P0346 may have number of causes. Here are some of the most common.
Ford Trucks / Mustang GT – An alternator phase problem, such as a blown diode or open coil, may cause so much electrical interference that the CMP signal gets distorted, causing a P0341 / P0346 DTC to set, among others, in spite of there being no actual problem with the CMP sensor or wiring.
What are the symptoms of code P0341 ?
How do you troubleshoot code P0341 ?
Because P0341 and P0346 refer to a circuit problem, do not automatically condemn the CMP sensor. That’s not to say that it might not be the sensor itself, but replacing the sensor is not always going to fix the problem. Get out your wiring diagram and DVOM (digital volt-ohm meter) for this next part.
- Sensor Inspection
- Other Problems – In case no problems can be found in the CMP sensor or its wiring, it may be that P0341 or P0346 are simply auxiliary fault codes. A jumped timing belt, faulty crankshaft position sensor signal or circuit, or engine misfire, may be the primary problem. Double check these before coming back to the CMP.
Codes Related to P0341
DTC P0341 or P0346 may be accompanied by other DTCs, such as P0300 Random Misfire, P0725 Engine Speed Sensor Circuit, or P0335 Crankshaft Position Sensor Circuit Malfunction.
BAT Team Discussions for P0341
- 1998 Tahoe DTC p1345
Got the code of p1345. Its on a 1998 tahoe with a 5.7lt. I've been doing some reseach on this and I've read the question that 2 people have asked. It was "Did you take it off road and put it in the mud?" and my answer is yes. What is the problem I might be looking for, cause I can't figure it out. T... - UPDATE 94 BUICK SUPER CHARGED--- still need help
I am still battling this one, please see old post. This one has been a buggarrrr!!! right now it has died going down the road, noticed low voltage when it died. We installed new alternator and battery, just to eliminate possible voltage issue, last time it died " after new battery and alt" I use a ... - 1994 Old 98
Hey guys, Thanks for the information regarding the correct obd tool to use in order to get my trouble codes. I now know DTC P0341 is the problem that I am looking at. If I understand this code correctly it is indication that my problem is either the crank sensor or the cam sensor. Is this correc... - Car driven with no oil: 2000 Audi A4 2.8 153000 miles
All oil in the pan drained out due to a big leak. No warning light displayed on the console either because the sensor wires were damaged. So while driving on the freeway the car stopped and never started again. I took the old pan out and noticed metal shavings in it. It was obvious engine has been d... - 2001 Buick Lesabre relearn procedure
I'm can't say for sure, but you may only have to warm engine, then rev to limiter twice, then return to idle. Another possibility might be that you have to do nothing, because "the variation" is not large enough to set a code. Alldata says...The crankshaft position system (CKP) variation compensati...
peugeot 407 petrol
fault code p0341 cylinder referance sensor 1
can a faulty coil pack throw up this code
or is it more likely to be the cam timing
car starts after 3 goes of turning over
many thanks
Tengo un malibu1998 3.1L V6 y no encuentro la ubicación del sensor de árbol de levas he visto muchos manuales de taller y mencionan que esta debajo de la licuadora de dirección hidráulica ya lo busque y no esta ahí donde lo puedo localizar ya que menciona que esta en el banco 1
Working on a 2005 Honda Accord four banger car runs perfect just kicking your light sensors were replaced still has the light on timing chain does not rattle or make any noise but the car does have 200,000 miles on it so is there anything else I should check? Before changing the chain?
Hola mi carro es un Aveo 2006 el escáner me arroja está falla pero enciende sin problemas, o será que el sensor del cigüeñal suplanta el CMP?
