P0340 – Camshaft position (CMP) sensor A, bank 1 circuit malfunction
Last Updated 2020-12-10
P0340 | Camshaft position (CMP) sensor A, bank 1 circuit malfunction (Buy Part On Amazon) | Wiring, CMP sensor, ECM |
What Does Code P0340 Mean?
The camshaft position sensor reacts to a toothed wheel on the camshaft, which gives the ECU constant information on its speed and position. Of course, the CMP is located on the engine, usually somewhere on the cylinder head, so it transmits CMP data to the ECU using wires. If the ECU cannot detect a CMP signal, it will set DTC P0340 or DTC P0345 – Camshaft Position Sensor Circuit Malfunction. If your engine has only one CMP, such as an inline-four-cylinder, the only CMP code available is for Bank 1, P0340. On the other hand, V6 or V8 engines have two banks, Bank 1 and Bank 2, and would therefore have two CMPs, so DTC P0345 would refer to Bank 2. Sensor A indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the intake camshaft. Sensor B codes pertain to the exhaust camshaft.
What are the common causes of code P0340?
Depending on year, make, and model, DTC P0340 or P0345 may have number of causes. Here are some of the most common.
Ford Trucks / Mustang GT – An alternator phase problem, such as a blown diode or open coil, may cause so much electrical interference that the CMP signal gets distorted, causing a P0340 / P0345 DTC to set, among others, in spite of there being no actual problem with the CMP sensor or wiring.
What are the symptoms of code P0340?
How do you troubleshoot code P0340?
Because P0340 and P0345 refer to a circuit problem, do not automatically condemn the CMP sensor. That’s not to say that it might not be the sensor itself, but replacing the sensor is not always going to fix the problem. Go to All Data DIY or other source and get out your wiring diagram and DVOM (digital volt-ohm meter) for this next part.
- Sensor Inspection
- Other Problems – In case no problems can be found in the CMP sensor or its wiring, it may be that P0340 or P0345 are simply auxiliary fault codes. A jumped timing belt, faulty crankshaft position sensor signal or circuit, or engine misfire, may be the primary problem. Double check these before coming back to the CMP.
Codes Related to P0340
DTC P0340 or P0345 may be accompanied by other DTCs, such as P0300 Random Misfire, P0725 Engine Speed Sensor Circuit, or P0335 Crankshaft Position Sensor Circuit Malfunction.
I am driving Renault megane2.sometimes no power.it just stall,when i check p0340.after it loose power.I stop 4 few minutes then it goes.what might be problem. pls help.
I don’t know about cars but I got PO340 and Pending 232 what does that mean? Have a 2012 Mercedes benz 250C, 4 cyclinder/
Regarding p0340 cam sensor and wiring are good! 1995 mustang 3.8 Heavily moded only owner. Going to test alternator voltage regulator and crank sensor. I’ll post what I find the 340 code is Only code I’m getting car runs Very Well no starting problems!! The torque light pro keeps barking threw my stareo P0340 Bank 1 circuit A!!! I did notice yesterday the voltage meter was kinda low around 12V my car stock spec calls
13 – 15v
What did u find, did u get fixed
Code P0344
Camshaft position sensor A circuit
Intermittent Bank 1
Or single sensor
Where to start?
Dodge Ram 1500 V8Hemi 2012
How to find the problem of the groung to ground problem I can check mine and it gives me a reading .14 on both cam and crank and it says it supposed to 0.000 where do I neex to start looking for thw problem
One. The pcm driver. Two the ignition. A terminal at the pcm should be a ground for the crank sensor, and a pin for the cam sensor. Follow the wires from the sensor to the pcm connector and check for good solid ground connection. It may be in a big bundle of wires so you may have to cut throuh some loom and tape. There should be no voltage on the ground wires. 0.14v is a problem sir. Good luck finding the open, or short.
i change vave seal and the timming as well but now having a hard start also getting fault code intake camshaft bank 1 above maximum threshold
Hi I have missed sunny 2008 I get sem cod p0340 wen star not working can you hello me
O-
This is on a 2008 Nissan Sunny? Make sure everything is connected. This refers to the camshaft position sensor circuit, so it might be the sensor itself or the circuit between the CMP and ECM. I found this diagnostic process over on nisentra.com that might help: P0340
thank you very much tarqmhmwdaldbas
I’m facing p0340 error on hyundai santro club, after driving 14km or shorter. Car engine stopped and lgnition lights aperared. It doesn’t start at least before 15 min but again stopped suddenly. It start propyl after waiting minimum 1 haur wait. It’s behavior is different every time. Plz guide
hi I’m driving a 2003 Mitsubishi Eclipse GT I replace the timing replace the timing I have good fuel spark but the motor will not run the codes are reading P0340 and p0335 I replace the crankshaft position sensor it still will not run and I cannot find the camshaft position sensor I’ve been on this car day and night please help any suggestions or where is the camshaft position sensor located at
[…] Hybrid Edition Join Date: Sep 2008 Location: Mother Earth Posts: 6,913 P0340 ? Camshaft position (CMP) sensor A, bank 1 circuit malfunction ? OBD2 Trouble Codes If you're "Feeling the Bern", I'd get checked out for STD's. bucksnort is […]
I need a picture of my engine to find my cmp sensor. I have a 2002 6 cylinder Chevrolet Trailblazer Ltz 4.2. So I might put the P0340 sensor problem in myself
I have a 2005 Dodge Grand Caravan that won’t start. Going up the interstate it overheated and shut down. I have replaced the leaking radiator with a new one. I have replaced the starter and the camshaft position sensor and still not starting. The error codes continue to read the camshaft position sensor being the problem. The starter sounds like it is just spinning and not engaging. I am lost now. Please give me some direction.
If possible check the circuit in the socket and also check the engine timing….. .
My Nissan quest 2006 it does not start what can be ? I hava be change camshaft position. Senson bank 2 y the problem continue, help me is possible.
Concerning the “position plate” that fires the CMP: are its “teeth” simply steel, or are they magnetized? Does the CMP fire just on proximate steel, or does it require a magnet to fire it?
Hiya Joseph,
To answer your question, the toothed wheel is not magnetised, just steel. The sensor itself is magnetic, and as the tooth passes the sensor, it effects a change in the magnetic field. This change is what the sensor detects, sending a signal back to the ECM.
