P0334 – Knock sensor (KS) 2, bank 2 -circuit intermittent
Last Updated 2016-02-01
P0334 | Knock sensor (KS) 2, bank 2 -circuit intermittent | Wiring, poor connection, KS, ECM |
What Does Code P0334 Mean?
(Courtesy: azosensors.com)
P0334 stands for knock sensor circuit intermittent. This means the PCM has detected a problem with the knock sensor or its circuit. Some vehicles may be equipped with two knock sensors. Code P0334 pertains to the sensor on bank 2 (the opposite side of the engine where the #2 cylinder is located).
What are the common causes of code P0334 ?
To sum things up, the common causes for code P0334 are as follows:
- Failed knock sensor
- Failed PCM
What are the symptoms of code P0334 ?
How do you troubleshoot code P0334 ?
The following steps will help you troubleshoot a P0334 code:
- Test the sensor output
An old-style knock sensor
(Courtesy: autobarn.net)
(Courtesy: youtube.com)
A resonant style knock sensor
(Courtesy: msextra.com)
- Check the circuit
If the knock sensor checks out OK, but you still have P0334 code illuminated, you’ll need to check the sensor circuit. Using a digital multimeter set to the ohms, connect one side of the meter to the harness side of the knock sensor connector and the other to the knock sensor input pin on the PCM. This tests for continuity between the sensor and PCM. If your meter reads OL, there is an open somewhere in the circuit that must be repaired. If not, the PCM is likely the problem and should be replaced.
(Courtesy: alldata.com)
(Courtest: alldata.com)
Codes Related to P0334
- DTC P0325: Knock Sensor (KS) Circuit Malfunction
- DTC P0326: Knock Sensor (KS) Performance
- DTC P0327: Knock Sensor (KS) Circuit Low Voltage Bank 1
- DTC P0329: Knock Sensor (KS) Circuit Intermittent Bank 1
- DTC P0330: Knock Sensor (KS) Circuit Bank 2
- DTC P0331: Knock Sensor (KS) Performance
- DTC P0332: Knock Sensor (KS) Circuit Low Voltage Bank 2
