P0333 – Knock sensor (KS) 2, bank 2 -high input
Last Updated 2016-02-01
P0333 | Knock sensor (KS) 2, bank 2 -high input (Buy Part On Amazon) | Wiring short to positive, KS incorrectly tightened, KS, ECM |
What Does Code P0333 Mean?
(Courtesy: azosensors.com)
P0333 stands for knock sensor high input. This means the PCM has detected a problem with the knock sensor or its circuit. Some vehicles may be equipped with two knock sensors. Code P0333 pertains to the sensor on bank 2 (the opposite side of the engine where the #1 cylinder is located).
What are the common causes of code P0333 ?
To sum things up, the common causes for code P0333 are as follows:
- Failed knock sensor
- Failed PCM
What are the symptoms of code P0333 ?
How do you troubleshoot code P0333 ?
The following steps will help you troubleshoot a P0333 code:
- Test the sensor output
An old-style knock sensor
(Courtesy: autobarn.net)
(Courtesy: youtube.com)
A resonant style knock sensor
(Courtesy: msextra.com)
- Check the circuit
If the knock sensor checks out OK, but you still have P0333 code illuminated, you’ll need to check the sensor circuit. Using a digital multimeter set to the ohms, connect one side of the meter to the harness side of the knock sensor connector and the other to the knock sensor input pin on the PCM. This tests for continuity between the sensor and PCM. If your meter reads OL, there is an open somewhere in the circuit that must be repaired. If not, the PCM is likely the problem and should be replaced.
(Courtesy: alldata.com)
(Courtest: alldata.com)
Have a 2007 fj cruier. p0333 code (knock sensor bank 2) I think there was a rat eating my cable from the nkock sensor. Where can i get more inf. about removing the fj intake. Thanks in advance
I have replaced both knock sensors and the light is still on giving me the p0333 code and you can’t hear any abnormal pinging or knocking is there any steps I can take from this point or what is the next step I should take
I am having a problem starting my tocama in the morning ,
Once starts up and do not have a problem starting it up again .
What could be the reason ?
It should also be noted that a knock from the engine on bank b could cause the code, the knock will create a high voltage triggering the code. Please let me know what you think?
Yes, an internal engine mechanical problem could set this code. You are correct.
