P0330 – Knock sensor (KS) 2, bank 2 -circuit malfunction
Last Updated 2016-01-28
P0330 | Knock sensor (KS) 2, bank 2 -circuit malfunction (Buy Part On Amazon) | Wiring, KS, ECM |
What Does Code P0330 Mean?
(Courtesy: azosensors.com)
P0330 stands for knock sensor circuit malfunction. This means the PCM has detected a problem with the knock sensor or its circuit. Some vehicles may be equipped with two knock sensors such as in this case. Code P0330 pertains to the sensor on bank 2 (the side of the engine opposite where the #1 cylinder is located).
What are the common causes of code P0330 ?
To sum things up, the common causes for code P0330 are as follows:
- Failed knock sensor
- Failed PCM
What are the symptoms of code P0330 ?
How do you troubleshoot code P0330 ?
The following steps will help you troubleshoot a P0330 code:
- Test the sensor output
An old-style knock sensor
(Courtesy: autobarn.net)
(Courtesy: youtube.com)
A resonant style knock sensor
(Courtesy: msextra.com)
- Check the circuit
If the knock sensor checks out OK, but you still have P0330 code illuminated, you’ll need to check the sensor circuit. Using a digital multimeter set to the ohms, connect one side of the meter to the harness side of the knock sensor connector and the other to the knock sensor input pin on the PCM. This tests for continuity between the sensor and PCM. If your meter reads OL, there is an open somewhere in the circuit that must be repaired. If not, the PCM is likely the problem and should be replaced.
(Courtesy: alldata.com)
(Courtest: alldata.com)
Codes Related to P0330
- DTC P0324: Knock Sensor (KS) Module Performance
- DTC P0325: Knock Sensor (KS) Circuit Bank 1
- DTC P0326: Knock Sensor (KS) Performance
- DTC P0327: Knock Sensor (KS) Circuit Low Voltage Bank 1
- DTC P0332: Knock Sensor (KS) Circuit Low Voltage Bank 2
Will the car run just fine with one good knock sensor. My ford has a code on bank 2 – P0330 but car feels and sounds fine. Can I still drive while I wait for a new sensor?
