P0329 – Knock sensor (KS) 1, bank 1 -circuit intermittent
P0329 | Knock sensor (KS) 1, bank 1 -circuit intermittent (Buy Part On Amazon) | Wiring, poor connection, KS, ECM |
- What Does Code P0329 Mean?
- What are the common causes of code P0329 ?
- What are the symptoms of code P0329 ?
- How do you troubleshoot code P0329 ?
- Codes Related to P0329
- Get Help with P0329
(Courtesy: azosensors.com)
P0329 stands for knock sensor circuit intermittent. This means the PCM has detected a problem with the knock sensor or its circuit. Some vehicles may be equipped with two knock sensors. Code P0329 pertains to the sensor on bank 1 (the side of the engine where the #1 cylinder is located).
To sum things up, the common causes for code P0329 are as follows:
- Failed knock sensor
- Failed PCM
The following steps will help you troubleshoot a P0329 code:
- Test the sensor output
An old-style knock sensor
(Courtesy: autobarn.net)
(Courtesy: youtube.com)
A resonant style knock sensor
(Courtesy: msextra.com)
- Check the circuit
If the knock sensor checks out OK, but you still have P0329 code illuminated, you’ll need to check the sensor circuit. Using a digital multimeter set to the ohms, connect one side of the meter to the harness side of the knock sensor connector and the other to the knock sensor input pin on the PCM. This tests for continuity between the sensor and PCM. If your meter reads OL, there is an open somewhere in the circuit that must be repaired. If not, the PCM is likely the problem and should be replaced.
(Courtesy: alldata.com)
(Courtest: alldata.com)
- DTC P0324: Knock Sensor (KS) Module Performance
- DTC P0326: Knock Sensor (KS) Performance
- DTC P0327: Knock Sensor (KS) Circuit Low Voltage Bank 1
- DTC P0330: Knock Sensor (KS) Circuit Bank 2
- DTC P0332: Knock Sensor (KS) Circuit Low Voltage Bank 2
This is really good
