P0328 – Knock sensor (KS) 1, bank 1 -high input
Last Updated 2019-03-31
P0328 | Knock sensor (KS) 1, bank 1 -high input (Buy Part On Amazon) | Wiring short to positive, KS incorrectly tightened, KS, ECM |
What Does Code P0328 Mean?
(Courtesy: azosensors.com)
P0328 stands for knock sensor high input. This means the PCM has detected a problem with the knock sensor or its circuit. Some vehicles may be equipped with two knock sensors. Code P0328 pertains to the sensor on bank 1 (the side of the engine where the #1 cylinder is located).
What are the common causes of code P0328 ?
To sum things up, the common causes for code P0328 are as follows:
- Failed knock sensor
- Failed PCM
What are the symptoms of code P0328 ?
How do you troubleshoot code P0328 ?
The following steps will help you troubleshoot a P0328 code:
- Test the sensor output
An old-style knock sensor
(Courtesy: autobarn.net)
(Courtesy: youtube.com)
A resonant style knock sensor
(Courtesy: msextra.com)
- Check the circuit
If the knock sensor checks out OK, but you still have P0328 code illuminated, you’ll need to check the sensor circuit. Using a digital multimeter set to the ohms, connect one side of the meter to the harness side of the knock sensor connector and the other to the knock sensor input pin on the PCM. This tests for continuity between the sensor and PCM. If your meter reads OL, there is an open somewhere in the circuit that must be repaired. If not, the PCM is likely the problem and should be replaced.
(Courtesy: alldata.com)
(Courtest: alldata.com)
Berapa harga knock sensor p0328
