P0327 – Knock sensor (KS) 1, bank 1 -low input
Last Updated 2016-02-01
P0327 | Knock sensor (KS) 1, bank 1 -low input | Insecure KS, poor connection, wiring short to earth, incorrectly tightened, KS, ECM |
What Does Code P0327 Mean?
(Courtesy: azosensors.com)
P0327 stands for knock sensor low input. This means the PCM has detected a problem with the knock sensor or its circuit. Some vehicles may be equipped with two knock sensors. Code P0327 pertains to the sensor on bank 1 (the side of the engine where the #1 cylinder is located).
What are the common causes of code P0327 ?
To sum things up, the common causes for code P0327 are as follows:
- Failed knock sensor
- Failed PCM
What are the symptoms of code P0327 ?
How do you troubleshoot code P0327 ?
The following steps will help you troubleshoot a P0327 code:
- Test the sensor output
An old-style knock sensor
(Courtesy: autobarn.net)
(Courtesy: youtube.com)
A resonant style knock sensor
(Courtesy: msextra.com)
- Check the circuit
If the knock sensor checks out OK, but you still have P0327 code illuminated, you’ll need to check the sensor circuit. Using a digital multimeter set to the ohms, connect one side of the meter to the harness side of the knock sensor connector and the other to the knock sensor input pin on the PCM. This tests for continuity between the sensor and PCM. If your meter reads OL, there is an open somewhere in the circuit that must be repaired. If not, the PCM is likely the problem and should be replaced.
(Courtesy: alldata.com)
(Courtest: alldata.com)
Codes Related to P0327
- DTC P0324: Knock Sensor (KS) Module Performance
- DTC P0325: Knock Sensor (KS) Circuit Bank 1
- DTC P0326: Knock Sensor (KS) Performance
- DTC P0330: Knock Sensor (KS) Circuit Bank 2
- DTC P0332: Knock Sensor (KS) Circuit Low Voltage Bank 2
BAT Team Discussions for P0327
- 1995 Lumina to 1999 Lumina tanny change
1999 Lumina seems to be missing second gear, even when shifted manually Scanner shows sec gear but car shift feels like fist to third gear ??? Codes that cleared and did not come back in the time I drove car. P0327 Knock sensor, P0742 Torq conv. clutch stuck on. P0f23 & P146 unknown codes Trans pr... - Need more info about Chevy knock sensor
Here Dan....see if this helps.....Jim........DTC P0332 CIRCUIT DESCRIPTION The knock sensor (KS) system enables the powertrain control module (PCM) to control the ignition timing for the best possible performance while protecting the engine from potentially damaging levels of detonation. The syst... - Head scratcher
If it was a Knock sensor issue, the PCM would have coded either a P0325, P0326, P0327. The knock sensor module is located within the PCM. If the PCM detects a faulty wiring/or a knock sensor faulty. It will code a P0327....
How do you know which port 1 is or port 2 when it comes to knicker sensirs
[…] (ECM) and if there is an error give a code to the problem. For example here it shows a P0327 Code which is a Knock Sensor problem. It could be a bad sensor or the wiring harness and connectors. […]
Could i be getting this code because it was very rainy on my way home and the engine got a little wet?
Nate-
Possibly, if the rain caused a partial short-to-ground in the knock sensor circuit. Does the code come up when the engine is dry? You can test this on a dry day by spraying down your engine with water and seeing if it trips the code. If so, it could mean you have some cracked or chafed insulation, loose connector, or poor connector seal (blowing out the connector and stuffing it with dielectric grease can help in that case, or else a new knock sensor pigtail).
First of all thank you for such elaboration regarding the knocking sensor. I have Cadd Esclade 2008 having a code P0327. The further detail shows Right Bank Knock sensor failed. Visual inspection suggest that the wire is damaged. Though the wire is repaired bur still the code is still there. Knock sensor is replaced with new AC delco knock sensor but even then the code didn’t go. At last the connectivity is checked again which came out to be okay. The code is still there. Should I consider the issue lies with the PCM instead of knock sensor itself or should I have something else to try before changing the PCM.
