P0326 – Knock sensor (KS) 1 , bank 1 -range/performance problem
Last Updated 2016-02-01
P0326 | Knock sensor (KS) 1 , bank 1 -range/performance problem (Buy Part On Amazon) | Wiring, KS incorrectly tightened, KS |
What Does Code P0326 Mean?
(Courtesy: azosensors.com)
P0326 stands for knock sensor circuit performance. This means the PCM has detected a problem with the knock sensor or its circuit. Some vehicles may be equipped with two knock sensors. Code P0326 pertains to the sensor on bank 1 (the side of the engine where the #1 cylinder is located).
What are the common causes of code P0326 ?
To sum things up, the common causes for code P0326 are as follows:
- Failed knock sensor
- Failed PCM
What are the symptoms of code P0326 ?
How do you troubleshoot code P0326 ?
The following steps will help you troubleshoot a P0326 code:
- Test the sensor output
An old-style knock sensor
(Courtesy: autobarn.net)
(Courtesy: youtube.com)
A resonant style knock sensor
(Courtesy: msextra.com)
- Check the circuit
If the knock sensor checks out OK, but you still have P0326 code illuminated, you’ll need to check the sensor circuit. Using a digital multimeter set to the ohms, connect one side of the meter to the harness side of the knock sensor connector and the other to the knock sensor input pin on the PCM. This tests for continuity between the sensor and PCM. If your meter reads OL, there is an open somewhere in the circuit that must be repaired. If not, the PCM is likely the problem and should be replaced.
(Courtesy: alldata.com)
(Courtest: alldata.com)
Codes Related to P0326
- DTC P0324: Knock Sensor (KS) Module Performance
- DTC P0325: Knock Sensor (KS) Malfunction
- DTC P0327: Knock Sensor (KS) Circuit Low Voltage Bank 1
- DTC P0330: Knock Sensor (KS) Circuit Bank 2
- DTC P0332: Knock Sensor (KS) Circuit Low Voltage Bank 2
my vehicle. car , 2010 chevy equinox, has a ping sound, when i start running the vehicle. it has has a scan tool on it,called a sinc and drive, aslo gives codes when engine is running rough. it gave me a code of P0 326, it says it is a knock sensor, what do you think
