P0325 – Knock sensor (KS) 1 , bank 1 -circuit malfunction
Last Updated 2016-09-06
P0325 | Knock sensor (KS) 1 , bank 1 -circuit malfunction | Wiring, poor connection, KS |
What Does Code P0325 Mean?
(Courtesy: azosensors.com)
P0325 stands for knock sensor circuit malfunction. This means the PCM has detected a problem with the knock sensor or its circuit. Some vehicles may be equipped with two knock sensors. Code P0325 pertains to the sensor on bank 1 (the side of the engine where the #1 cylinder is located).
What are the common causes of code P0325 ?
To sum things up, the common causes for code P0325 are as follows:
- Failed knock sensor
- Failed PCM
What are the symptoms of code P0325 ?
How do you troubleshoot code P0325 ?
The following steps will help you troubleshoot a P0325 code:
- Test the sensor output
An old-style knock sensor
(Courtesy: autobarn.net)
(Courtesy: youtube.com)
A resonant style knock sensor
(Courtesy: msextra.com)
- Check the circuit
If the knock sensor checks out OK, but you still have P0325 code illuminated, you’ll need to check the sensor circuit. Using a digital multimeter set to the ohms, connect one side of the meter to the harness side of the knock sensor connector and the other to the knock sensor input pin on the PCM. This tests for continuity between the sensor and PCM. If your meter reads OL, there is an open somewhere in the circuit that must be repaired. If not, the PCM is likely the problem and should be replaced.
(Courtesy: alldata.com)
While old-style knock sensors ground through the sensor itself, resonant style sensors typically have a separate ground circuit. In this case, you’ll want to use a digital multimeter to ensure there is a good ground before condemning the PCM. Start by consulting the wiring diagram for your vehicle from All DATA DIY to determine which pin on the connector is power and which is ground. Next, connect the red multimeter lead to the battery positive terminal and the black lead to ground. You should see a reading of about 12 volts indicating a good ground. If not, you’ll need to consult the ground side of the wiring diagram to find where the circuit fault lies.
(Courtest: alldata.com)
Codes Related to P0325
- DTC P0324: Knock Sensor (KS) Module Performance
- DTC P0326: Knock Sensor (KS) Performance
- DTC P0327: Knock Sensor (KS) Circuit Low Voltage Bank 1
- DTC P0330: Knock Sensor (KS) Circuit Bank 2
- DTC P0332: Knock Sensor (KS) Circuit Low Voltage Bank 2
BAT Team Discussions for P0325
- 97 altima miss
P0325 P0304 #4 CYL. i have checked plug, wire, and injector on that cyl i have took a look at cap and rotor but did not see anything out of ordinary if you drove the car you would never know, drives just fine does anyone have a diag procedure on these codes they can post?? thanks i know they ha... - 2000 Nissan Quest
Have check engine light on (2000 Nissan Quest), codes P0130; P0325 and P01148. Does anyone knows the cause of those codes.... - service engine light on
Last time work was done was back in may, since then I put on between one or two thousand miles on the car the engine light was on the intake manifold gasket was replaced it had been running rough, and the knock sensor was replaced the codes back then were P0304 and P0325. havent had a chance to look... - '97 Nissan Maxima 3.0L V-6
Well, I read codes and got P0335 (crank position sensor A), P0325 (knock sensor 1), P0100 (MAF), and P0505 (IAC). I checked everything visually, then started it up and looked at live-data. It all looked reasonably normal, and the MAP correlated to a mechanical gage I T'ed in at the FPR (couldn't f... - Trouble codes PO457
P0457 is a unusual code to see alone- often there are other EVAP issues. - did this happen after refuel or replaced gas cap? the p0325 is a KS before we go chasing wiring isues- is there an exhaust leak? is engine making noise ticking knocking? Do not use the key on key off trick to get codes WI...
Can knock sensor malfunction cause gear shift problems? My kluger sometimes fails to shift to gear 4 when the engine check light turns on.
Hi,
I looked online and the Kluger appears to be the same thing as the Toyota Highlander here in the states. My guess is that what you are experiencing is the vehicle going into fail-safe mode. In the case of your vehicle, the ECM will delay the ignition timing to maximum retardation. You may interpret this as problem with the transmission shifting. With this particular code, it doesn’t look like the ECM would prevent shift solenoid operation in fail safe mode. Hope this helps.
Hello everyone!i have a toyota caldina 1AZ-FSE engine .this have a trouble code p0325 problem.i replaced ecm & knock sensor but when i am driving at 82C , my car is always showed p0325 malfunction . Can you help me and how to test knock sensor a good or bad .
Hi,
We do not have the Caldina here in the states, but the RAV4 uses the 1AZ-FSE engine, so I will use it for reference. The knock sensor contains a piezoelectric element which generates a voltage when it becomes deformed. This happens when the cylinder block vibrates due to knocking. If engine knocking occurs, ignition timing will be suppressed to prevent it. If you’ve already replaced the sensor and the ECM, I would check the wiring between the two. To do this, remove the connector from the PCM and knock sensor. Use a digital multimeter set to ohms and touch one lead to the knock sensor signal wire to the PCM and the other to knock sensor pin at the PCM. If the meter reads out of limits (OL), there is an open circuit. You’ll need to consult the factory repair information to trace the problem. This appears to be a single wire sensor, which grounds through the body.
I got Honda CRV 2005 model.
It showing me PO325PND, PO325CNF, Knock Sensor 1, MOD $09, Knock Sensor 1 Circuit (Bank1), Engine or Signal Sensor, Right Front Wheel Speed sensor Malfunction.
Is there a serious problem? what is the impact if i do not repair it soon?
Hey there. Check that the knock sensor connector is fully seated. The knock sensor is near the starter, but I’m not sure how easy it is to get at it.
Hello
I need an assistance, my Camry 1999 model is showing error message p0325 on OBD2 scanner and also other codes p0500, p0753,p0758. Just to know if they are related and what to do. Thank you
