P0310 – Cylinder 10 -misfire detected
Mia
By Mia (Contact Me)
Last Updated 2017-08-26
P0310 Cylinder 10 -misfire detected
Engine mechanical fault, wiring, ignition/fuel system, injector, ECT/MAF sensor, ECM
  1. What Does Code P0310 Mean?
  2. What are the common causes of code P0310 ?
  3. What are the symptoms of code P0310 ?
  4. How do you troubleshoot code P0310 ?
  5. Get Help with P0310
A misfire is just what it sounds like; a cylinder that is not firing as it should.  The P0310 code is caused by a misfire on the number ten cylinder. The Misfire monitor diagnostic is based on variation in crankshaft velocity. The PCM determines this information using the crankshaft position sensor and camshaft position sensor. A misfiring cylinder slows down momentarily, so by monitoring the cam and crank sensor signals, the PCM can calculate when a misfire occurs.  A P0310 code tells you only that a misfire has been detected, not WHY the cylinder is misfiring.  That’s why with this code, a thorough diagnosis is mandatory.
Misfire Monitor
Different manufacturers implement OBD-II requirements slightly differently.  The misfire monitor is an OBD-II procedure which identifies a misfire.
The misfire monitor is a “continuous” monitor; it is always checking the crankshaft position sensor for a misfire.  It is important to note that the misfire monitor is very reliant on the crankshaft position sensor signal.  A faulty crankshaft position sensor will misdiagnose misfires!
When you encounter a single cylinder misfire, the causes of systemic misfires such as: fuel pumps, timing problems, EGR valve leaks, or crankshaft position sensors are less likely.  Individual spark plugs, fuel injectors and valves should be carefully examined for the cylinder.  For companion cylinders, the cylinder noted by the PCM may test fine.  Be sure to check its companion in the firing sequence.  For a P0310 code, the causes could be:
  • Cylinder #10 Spark Plug
  • Cylinder #10 Coil
  • Cylinder #10 Wiring
  • Cylinder #10 Fuel Injector
TIP: Check for a technical service bulletin. There could be a known repair for a single cylinder code.  Sometimes the PCM errors.
A misfire can cause vibrations at idle.  Engine performance including fuel economy will suffer.
Often, the best way to troubleshoot a single cylinder misfire is to swap ignition components between the misfiring cylinder and a good cylinder.  If the misfire moves with the sparkplug (for example) then the sparkplug would be the cause of the misfire.  If switching components with a good cylinder doesn’t eliminate the original misfire then there could be a problem with compression.
Compression problems can have a number of causes.  The most likely are exhaust valves or head gasket leaks.  If the engine is overheating or losing coolant there is a strong probability the gasket is damaged.
See articles P0300 & P0301 for in depth troubleshooting of the four misfire causes: fuel, spark, timing, and compression.
