P0303 – Cylinder 3 -misfire detected
Last Updated 2017-08-26
P0303 | Cylinder 3 -misfire detected (Buy Part On Amazon) | Engine mechanical fault, wiring, ignition/fuel system, injector, ECT/MAF sensor, ECM |
What Does Code P0303 Mean?
A misfire is just what it sounds like; a cylinder that is not firing as it should. The P0303 code is caused by a misfire on the number three cylinder. The Misfire monitor diagnostic is based on variation in crankshaft velocity. The PCM determines this information using the crankshaft position sensor and camshaft position sensor. A misfiring cylinder slows down momentarily, so by monitoring the cam and crank sensor signals, the PCM can calculate when a misfire occurs. A P0303 code tells you only that a misfire has been detected, not WHY the cylinder is misfiring. That’s why with this code, a thorough diagnosis is mandatory.
Misfire Monitor
Ignition Systems
Waste spark distributorless ignition systems (DIS) are common on many cars. Identifying and understanding a waste spark DIS can help with troubleshooting a misfire.
Your car has a waste spark DIS if there are fewer coils than cylinders. The system shares a coil with two spark plugs corresponding to companion cylinders – the cylinders which are opposite in the firing sequence.
The following Youtube video series describes the GM waste spark distributorless ignition system:
What are the common causes of code P0303 ?
When you encounter a single cylinder misfire, the causes of systemic misfires such as: fuel pumps, timing problems, EGR valve leaks, or crankshaft position sensors are less likely. Individual spark plugs, fuel injectors and valves should be carefully examined for the cylinder. For companion cylinders, the cylinder noted by the PCM may test fine. Be sure to check its companion in the firing sequence. For a P0303 code, the causes could be:
- Cylinder #3 Spark Plug
- Cylinder #3 Coil
- Cylinder #3 Wiring
- Cylinder #3 Fuel Injector
How do you troubleshoot code P0303 ?
Often, the best way to troubleshoot a single cylinder misfire is to swap ignition components between the misfiring cylinder and a good cylinder. If the misfire moves with the sparkplug (for example) then the sparkplug would be the cause of the misfire. If switching components to a good cylinder doesn’t eliminate the original misfire then there could be a problem with compression. See articles P0300 & P0301 for in depth troubleshooting of the four misfire causes: fuel, spark, timing, and compression.
I check the compresión is good, i change the spark plug,the injector and computer my car has the same problem
No meu caso em um Passat 2006 FSi Gas o tanque foi abastecido com etanol e causou o que entupimento do bico de injeção 03.
Feita a limpeza e tudo ficou normal.
check your compression have the same problem
