P0290 – Cylinder 10 -contribution/balance fault
P0290 | Cylinder 10 -contribution/balance fault (Buy Part On Amazon) | Wiring, fuel system, ECM |
- What Does Code P0290 Mean?
- What are the common causes of code P0290 ?
- What are the symptoms of code P0290 ?
- How do you troubleshoot code P0290 ?
- Codes Related to P0290
- Get Help with P0290
The engine control module (ECM) in the modern automobile continuously monitors and modifies engine operation to deliver the most efficient power. Using sensors, such as the crankshaft position sensor (CKP), and actuators, such as the fuel injectors, the ECM can also determine if something is so far out of specification that it can’t compensate. In this case, diagnosis and repair would be necessary to bring the engine back into specification.
Cylinder balance is one method the ECM uses to measure engine efficiency. You see, even if the engine is running at 2,500 rpm, that’s really only an average. With each cylinder firing, the crankshaft accelerates past 2,500 rpm, at that moment, and decelerates below 2,500 rpm. In the typical four-cylinder engine, there’s an impulse every 180°, while in an eight-cylinder engine, the impulse is every 90°, which explains why a V8 typically runs smoother than a V6 or an i4.
Using the CKP, the ECM can detect slight variations in engine rpm, that is, the acceleration of each power stroke, and can determine how much each cylinder is contributing to the engine, that is, the balance between each cylinder. If one or more cylinders doesn’t give as much impulse to the crankshaft, the ECM determines a fault, sets a diagnostic trouble code (DTC) in memory, and illuminates the malfunction indicator lamp (MIL). In case the ECM is finding fault with cylinder 10, DTC P0290 is defined as “Cylinder #10 Contribution/Balance Fault.”
Depending on year, make, and model, DTC P0290 may have number of causes. Here are some of the most common.
- Dirty Fuel Injectors – This is the number one cause of cylinder balance issues. This can be caused by dirty fuel, poor onboard fuel filtering, or carbon deposits. In some models, biodiesel has been blamed, perhaps for its low detergent qualities. Intensive fuel injector cleaning may solve the problem, but sometimes injector replacement is recommended.
- Improper Replacement – Some have gone forward with injector replacement, only to find it doesn’t solve the problem. If diesel fuel injectors are replaced, they must be run through a “learning procedure,” which enables the ECM and injector driver to learn the individual injector’s characteristics.
- Mechanical Problems – Anything that affects cylinder function, such as burnt valves, worn rings, or leaking head gasket, can affect power output of one or more cylinders, without necessarily causing a misfire.
Depending on the severity of the fault, you may or may not notice any drivability issues. Depending on the fault mode of the vehicle, you may experience reduced engine performance and fuel economy. If the problem is severe, you may experience rough idle or cylinder misfire.
Due to the complexity of the system, as well as tool expense and availability, you may be limited in your ability to diagnose this problem. Still, we’ll lay out some things that you can check, in addition to some of the main causes.
- Fuel Injectors –
- Electrical Check – Usually, you will not find open or short circuit problems along with cylinder balance DTCs, as there are dedicated DTCs for these issues. Additionally, a shorted or open fuel injector or wiring harness would result in a dead misfire, not a cylinder balance problem.
- Still, you should check the fuel injector and injector driver connectors for corrosion or evidence of water entry, which could reduce injector function. Repair or replace as necessary.
- If you have access to a digital oscilloscope, you can compare signals between the suspected fuel injector and its neighbors. The difference in waveforms may be small, but should be distinguishable. Check with a professional before condemning the fuel injector and replacing it.
- Functional Check – In addition to comparing waveforms, you can also use a mechanic’s stethoscope to compare the sound of the suspected fuel injector with its neighbors. You will hear a slight, but obvious, difference between a good injector and a faulty injector. Check with a professional before condemning the fuel injector and replacing it.
- Compression – Perform cylinder compression and leakdown tests to determine if you have a mechanical or sealing problem. Cylinder compression test readings shouldn’t vary more than 10%, and cylinder leakdown shouldn’t go over 10%. Cylinder leakdown also shouldn’t vary more than 10% between cylinders. If you have compression or leakdown issues, such as worn rings, valve problems, or a head gasket problem, these may result in poor cylinder balancing, but not necessarily cylinder misfire.
There are actually dozens of DTCs related to cylinder balance, so here are the main ones:
- DTC P0263 Cylinder #1 Contribution/Balance Fault
- DTC P0266 Cylinder #2 Contribution/Balance Fault
- DTC P0269 Cylinder #3 Contribution/Balance Fault
- DTC P0272 Cylinder #4 Contribution/Balance Fault
- DTC P0275 Cylinder #5 Contribution/Balance Fault
- DTC P0278 Cylinder #6 Contribution/Balance Fault
- DTC P0281 Cylinder #7 Contribution/Balance Fault
- DTC P0284 Cylinder #8 Contribution/Balance Fault
- DTC P0300 Random/Multiple Cylinder Misfire Detected
- DTC P0301 Cylinder #1 Misfire Detected
- DTC P0302 Cylinder #2 Misfire Detected
- DTC P0303 Cylinder #3 Misfire Detected
- DTC P0304 Cylinder #4 Misfire Detected
- DTC P0305 Cylinder #5 Misfire Detected
- DTC P0306 Cylinder #6 Misfire Detected
- DTC P0307 Cylinder #7 Misfire Detected
- DTC P0308 Cylinder #8 Misfire Detected
