P0274 – Injector 5 -circuit high
| P0274 | Injector 5 -circuit high (Buy Part On Amazon) | Wiring short to positive, injector, ECM |
Reading P0274 on your car
A basic adapter will show you P0274, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0274 – Injector 5 -circuit high yet.
