P0270 – Injector 4 -circuit low
P0270 | Injector 4 -circuit low (Buy Part On Amazon) | Wiring short to earth, injector, ECM |
- What Does Code P0270 Mean?
- What are the common causes of code P0270 ?
- What are the symptoms of code P0270 ?
- How do you troubleshoot code P0270 ?
- Codes Related to P0270
- Get Help with P0270
P0270 tells you where the problem is believed to be located, and what the problem appears to be. In this case, the code tells you it is a powertrain issue, that either the fuel mixture for the #4 cylinder is out of range or the fuel injector’s spray pattern is abnormal, or both.
Most often, the cause of the problem can be traced to the #4 cylinder fuel injector itself, or in the electrical circuitry associated with it. A dirty or plugged fuel injector, or a faulty fuel injector, are common causes, although somewhat surprisingly, an electrical malfunction of one type or another is more likely to be the source of the problem.
The Check Engine Light was illuminated because the vehicle’s powertrain control module (PCM) detected a drop in voltage in the fuel injection sensor in the #4 cylinder. It is in the PCM where OBD codes are generated when one or more of the sensors it monitors malfunctions, or gives an out-of-range reading.
A P0270 code will be generated when a low fuel injection sensor voltage for the #4 cylinder is detected. This sensor is an oxygen sensor, and the low voltage is often an indication that the injector’s spray pattern has changed and the #4 cylinder’s fuel mixture is too lean.
The symptoms arising from too lean of a fuel mixture can vary in their characteristics as well as in their intensity. What typically happens, is that when the PCM senses the fuel mixture is too lean, it enriches the fuel mixture. Unfortunately, it does so in all cylinders; not just the #4 cylinder.
One of the more prominent symptoms is engine knock. The lean mixture in the #4 cylinder creates a higher cylinder head temperature. This higher temperature causes premature denotation of the fuel-air vapor mixture, which in turn causes knocking.
Once the P0270 code has been detected, the first step to take is to try to determine whether the problem is with the fuel injector itself, or with its associated electrical connectors and wiring. The electrical connector, and the harness, should be inspected first to see if anything has become loose or has become corroded. If everything appears to be normal, the next step will be to see if the fuel injector is operating.
If you hear nothing, the injector has either failed, or it is not receiving electrical power. A voltmeter will indicate if power is present. If no voltage is present, the wiring to the fuel pump relay could be at fault. If power is present, check both terminals to see if the PCM injector driver is operating. If it is, the fuel injector needs to be flushed out or replaced. Your local auto parts store will usually have a direct injector flushing kit in stock, or one can purchased online if necessary. If cleaning the injector does not resolve the issue, it will need to be replaced.
There is always a possibility that more than one ODB code may be present when the Service Engine light illuminates. Should that be the case, a check should always be made to see if any of the other codes are still present once any code P0270 issues have been resolved.
- Code P0325 can be set by the knock sensor if it is receiving a low input, or if the sensor itself is malfunctioning.
- Code P0304 is set when a misfire is detected in the #4 cylinder. Problems other than fuel injector issues will sometimes set this code, but it Code P0270 has also been set, the problem likely involves the fuel injector or its circuitry.
- Code P0272 indicates the #4 cylinder is experiencing a fuel-related problem (usually referred to as a contribution/balance fault). and as such can assist in the diagnostic exercise. It will be set if the cylinder is contributing less power than the other cylinders (it must be within 5% of the others).
- Code P0271 is caused by high, rather than low reading of the #4 cylinder fuel injector sensor, and indicates the fuel mixture is too rich. Its symptoms are much the same as the P0270 symptoms, but the cause is usually different. A fuel that is too rich in anhydrous ethanol contains an excess of water vapor that can have an adverse effect on fuel injectors. This tends to be a problem with small engines rather than automotive engines.
My Chevrolet Optra 1.6 engine 2010 model is consuming a lot of fuel and not idling well, machine diagnose the following codes p0270, p0267, p0264, p0261please help me
my vehicle not start sometime the mechanic check and found these codes, p0261, p0267,p0270,p0264,p1505,p1507,and p0231 found inscanning. what is the problem/ please give me the suggestions.
