P0245 – Turbocharger (TC) wastegate regulating valve A circuit low
Last Updated 2020-08-19
P0245 | Turbocharger (TC) wastegate regulating valve A circuit low (Buy Part On Amazon) | Wiring short to earth, TC wastegate regulating valve, ECM |
What Does Code P0245 Mean?
OBD II fault code P0245 is a generic trouble code that is defined as “Turbocharger (TC) wastegate regulating valve “A” – circuit low”, and is set when the PCM (Powertrain Control Module) detects an unexpectedly low voltage in the circuits of a turbochargers’ wastegate control actuator. Note that this code only applies to forced induction engines that use a purely electrically controlled actuator to open and close the turbocharger’s wastegate, or dump valve, as it is also known.
Depending on the application and turbocharger’s design a wastegate or dump valve can have to different functions, although both functions have the same objective, which is to regulate the pressure in the boost system.
In practice, a wastegate can either allow excessive boost pressure to vent into the exhaust system, or it can be used to limit the amount of exhaust gas (which serves to drive the turbocharger) that enters the turbine side of the turbocharger.
In terms of operation, a wastegate is simply a kind of trapdoor in the turbocharger’s housing that allows excessive drive pressure to be vented into the exhaust. In designs that limit exhaust gas that enters the turbocharger, the limitation is used to limit the rotational speed of the compressor wheel as a means to control boost pressure. By way of contrast, turbocharger designs that use boost pressure to control the wastegate keep the wastegate closed, which allows all the exhaust gas that exits the engine to pass through the turbine side of the turbocharger to drive the compressor wheel, meaning that boost pressure can increase unchecked.
In the latter design, some boost pressure is diverted to act on a diaphragm in the actuator. When boost pressure is sufficient to overcome the spring tension, the actuator pulls open the wastegate, which relieves the pressure of the exhaust gas in the turbine side, which in turn, reduces boost pressure because the pressure in the compressor side of the turbocharger exerts a braking force on the compressor wheel.
While this system works reasonably well, it is very difficult to calibrate these designs to a point where boost pressure can be maintained within a very narrow range. In practice, these systems/designs produce significant fluctuations in boost pressure, which ultimately affects engine performance and efficiency.
Thus, to eliminate these fluctuations, modern boost control systems use advanced algorithms to calculate the speed of the turbine wheel at any given engine speed and throttle opening, this speed being the principal factor that determines boost pressure at any point in the engine’s operating range. Therefore, by using the PCM to control the wastegate with an electronically controlled actuator to limit the amount of exhaust gas that can act on the turbine, the speed of the turbine can be controlled precisely, which translates into precise control of the boost pressure throughout the engine’s operating range.
For this system to work, however, the PCM needs to monitor all relevant parameters continuously, and if it detects an abnormally low voltage or current in any circuit in the boost control system, it will recognize that it cannot control the boost pressure effectively, and it will set code P0245 and illuminate a warning light as a result.
Where is the P0245 sensor located?
This image shows an example of an electronically controlled turbocharger wastegate actuator. In this example, the green arrow indicated the electrical connector, while the red arrow indicates the control arm that links to the actual wastegate via a mechanical link.
Note that while the appearance and location of electrical wastegate actuators vary greatly, the single biggest difference between these types of actuators and vacuum-operated actuators is the fact that electrically operated actuators have no attachment points for a vacuum line. Note also that while some vacuum operated actuators have electrical connectors, the connector is used for a position sensor to report the status of the wastegate to the PCM. Thus, the electrical connector on a vacuum-operated wastegate is not directly related to boost-control functions, as such.
What are the common causes of code P0245 ?
Common causes of code P0245 could include one or more of the following-
- Damaged, burnt, shorted, disconnected, or corroded wiring and/or connectors in the boost control system (Most likely)
- Defective wastegate actuator
- Defective or malfunctioning boost pressure sensor
- Damaged or improperly adjusted actuator linkage
- Damaged turbocharger
- Damaged or sticking wastegate, but note that a sticking wastegate mechanism is more likely to produce a high voltage than a low voltage
- Failed or failing PCM, but note that since this a rare event, the fault must be sought elsewhere before any control module is replaced or reprogrammed
What are the symptoms of code P0245 ?
Most symptoms of code P0245 are largely similar across all applications, and could include one or more of the following-
- Stored trouble code and illuminated MIL (CHECK ENGINE) light
- In some cases, multiple codes relating to boost-control issues and/or misfires may be present along with P0245
- Varying degrees of power loss may be present, ranging from slight and barely noticeable, to severe enough to make the vehicle undrivable
- Fuel consumption may increase noticeably
- Emissions may increase measurably
- Engine may run roughly at high speeds, and especially in the range of engine speed where adequate boost pressure is required to maintain peak performance
- Engine may not idle, or the engine may stall at idling speeds, depending on the application and the exact nature of the problem
Is it safe to drive for a week for code P0245? The dealership isn’t able to see me until then.
I probably would not chance this issue. It could leave you stranded. It is an issue in the actuator wiring harness. I know ford was having issues with the pigtails at one point. They have an updated harness they can splice in. Sometimes it will cause the turbos to not function as programmed by the ecm and it can cut engine power significantly. If you could find another vehicle (I know it may be hard, sometimes ford offers loaner vehicles) it would be better.
