P0229 – Throttle position (TP) sensor C/accelerator pedal position (APP) sensor / switch C -circuit intermittent
Reinier
Last Updated 2016-06-05
P0229 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C -circuit intermittent
Wiring, poor connection, TP/APP sensor, ECM
  1. What Does Code P0229 Mean?
  2. What are the common causes of code P0229 ?
  3. What are the symptoms of code P0229 ?
  4. How do you troubleshoot code P0229 ?
  5. Codes Related to P0229
  6. Get Help with P0229
OBD II fault code is defined as “Throttle/Pedal Position Sensor/Switch C Circuit Intermittent”, and set when the PCM (Powertrain Control Module) detects a signal voltage from the TPS (Throttle Position Sensor) that does not correlate with the current engine speed.
NOTE: Code P0229 is only relevant to “drive-by-wire” systems in which there are no physical connections, such as throttle cables, between the accelerator pedal and the throttle plate/body. In some applications, there may be additional sensors and devices fitted to act as back-ups should a primary component or sensor fail.
tps-location
Note: Regardless of the code and the system affected, the word “Intermittent” refers to the fact that there is a sporadic, unpredictable, or, well, intermittent fault in that system. The most likely causes of codes that relate to intermittent faults include poor connections in both live and ground circuits, as well defective switches, relays, and sensors.
The most common causes of code P0229 could include the following-
  • Damaged, short circuited, or corroded wiring and connectors
  • Defective TPS or pedal sensors
  • Mal-adjusted TPS sensors
  • Mechanical wear in the TPS sensor and/or throttle body
  • Carbon deposits in the throttle body that impede the movement of the throttle plate
  • While PCM failures do happen, it is a rare event and the fault must be sought elsewhere before any controller is replaced
The most common symptoms of code P0229 are much the same on all vehicles, although the severity of some symptoms may vary from vehicle to vehicle. The most common symptoms may include the following-
  • Stored trouble code and illuminated CHECK ENGINE light
  • Visible black smoke from the tail pipe at start up
  • Hard – , or no-starting conditions may be present
  • Poor acceleration
  • Power loss
  • Rough idling
  • Hesitation or stalling upon acceleration
NOTE #1: Before starting an electrical diagnosis of code P0229, it is important to check the TPS for correct adjustment. Mechanical wear in the actuating mechanism often causes a deviation from factory settings, which can result in incorrect signals being generated. For instance, the most wear on TPS sensors occur within the first 20% or so of the throttle plates’ travel, meaning that the throttle plate can either “flutter” in this part of its travel, or not close fully. In the latter case, the initial adjustment will not agree with factory specs.
  • P0220 — Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
  • P0221 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem”
  • P0222 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Low Input”
  • P0223 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit High Input”
  • P0224 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Intermittent”
  • P0225 — Relates to “Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
  • P0226 – Relates to “Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem”
  • P0227 – Relates to “Throttle/Pedal Position Sensor/Switch C Circuit Low Input”
  • P0228 – Relates to “Throttle/Pedal Position Sensor/Switch C Circuit High Input”
  • P0229 – Relates to “Throttle/Pedal Position Sensor/Switch C Circuit Intermittent”
