P0226 – Throttle position (TP) sensor C/accelerator pedal position (APP) sensor / switch C -range/performance problem
| P0226 | Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C -range/performance problem (Buy Part On Amazon) | Accelerator cable adjustment, TP/APP sensor |
Where is the Throttle Position Sensor? See our guide to the Throttle Position Sensor – what it does, where it sits on the engine and how it fails.
- What Does Code P0226 Mean?
- What are the common causes of code P0226 ?
- What are the symptoms of code P0226 ?
- How do you troubleshoot code P0226 ?
- Codes Related to P0226
- Get Help with P0226
OBD II fault code is defined as “Throttle/Pedal Position Sensor/Switch C Range/Performance”, and set when the PCM (Powertrain Control Module) detects a signal voltage from the TPS (Throttle Position Sensor) that does not correlate with the current engine speed.
NOTE: Code P0226 is only relevant to “drive-by-wire” systems in which there are no physical connections, such as throttle cables, between the accelerator pedal and the throttle plate/body. In some applications, there may be additional sensors and devices fitted to act as back-ups should a primary component or sensor fail.
Note: A Range/Performance related code will be set when either a sensor or other component does not perform within the range the PCM (Powertrain Control Module) expects to see, given the current engine load/speed, and information gathered from other sensors. The possible causes of Range/Performance codes are likely to be defective sensors as easily as they are likely to be the result of wiring issues that affect the operation of the affected sensor or component, which means that with these codes, it is important to regard all sensors and components as part of the control circuit the code refers to.
The most common causes of code P0226 could include the following-
- Mal-adjusted TPS sensors
The most common symptoms of code P0226 are much the same on all vehicles, although the severity of some symptoms may vary from vehicle to vehicle. The most common symptoms may include the following-
- Poor acceleration
- Power loss
- Rough idling
NOTE #1: Before starting an electrical diagnosis of code P0226, it is important to check the TPS for correct adjustment. Mechanical wear in the actuating mechanism often causes a deviation from factory settings, which can result in incorrect signals being generated. For instance, the most wear on TPS sensors occur within the first 20% or so of the throttle plates’ travel, meaning that the throttle plate can either “flutter” in this part of its travel, or not close fully. In the latter case, the initial adjustment will not agree with factory specs.
- P0220 — Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
- P0221 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem”
- P0222 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Low Input”
- P0223 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit High Input”
- P0225 — Relates to “Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
- P0226 – Relates to “Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem”
- P0227 – Relates to “Throttle/Pedal Position Sensor/Switch C Circuit Low Input”
- P0228 – Relates to “Throttle/Pedal Position Sensor/Switch C Circuit High Input”
- P0229 – Relates to “Throttle/Pedal Position Sensor/Switch C Circuit Intermittent”
Reading P0226 on your car
A basic adapter will show you P0226, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
