P0223 – Throttle position (TP) sensor B/accelerator pedal position (APP) sensor / switch B -high input
Last Updated 2016-05-25
P0223 | Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B -high input (Buy Part On Amazon) | Wiring short to positive, TP/APP sensor, ECM |
What Does Code P0223 Mean?
OBD II fault code is defined as “Throttle/Pedal Position Sensor/Switch B High Input”, and set when the PCM (Powertrain Control Module) detects a signal voltage from the TPS (Throttle Position Sensor) that does not correlate with the current engine speed.
NOTE: Code P0223 is only relevant to “drive-by-wire” systems in which there are no physical connections, such as throttle cables, between the accelerator pedal and the throttle plate/body. In some applications, there may be additional sensors and devices fitted to act as back-ups should a primary component or sensor fail.
What are the common causes of code P0223 ?
The most common causes of code P0223 could include the following-
- Mal-adjusted TPS sensors
What are the symptoms of code P0223 ?
The most common symptoms of code P0223 are much the same on all vehicles, although the severity of some symptoms may vary from vehicle to vehicle. The most common symptoms may include the following-
- Poor acceleration
- Power loss
- Rough idling
How do you troubleshoot code P0223 ?
NOTE #1: Before starting an electrical diagnosis of code P0223, it is important to check the TPS for correct adjustment. Mechanical wear in the actuating mechanism often causes a deviation from factory settings, which can result in incorrect signals being generated. For instance, the most wear on TPS sensors occur within the first 20% or so of the throttle plates’ travel, meaning that the throttle plate can either “flutter” in this part of its travel, or not close fully. In the latter case, the initial adjustment will not agree with factory specs.
Codes Related to P0223
- P0220 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Malfunction”
- P0221 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem”
- P0222 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Low Input”
