P0220 – Throttle position (TP) sensor B/accelerator pedal position (APP) sensor / switch B -circuit malfunction
P0220 | Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B -circuit malfunction (Buy Part On Amazon) | Wiring, TP/APP sensor, ECM |
- What Does Code P0220 Mean?
- What are the common causes of code P0220 ?
- What are the symptoms of code P0220 ?
- How do you troubleshoot code P0220 ?
- Codes Related to P0220
- Get Help with P0220
OBD II fault code is defined as “Throttle/Pedal Position Sensor/Switch B Circuit Malfunction”, and set when the PCM (Powertrain Control Module) detects a signal voltage from the TPS (Throttle Position Sensor) that does not correlate with the current engine speed.
NOTE: Code P0220 is only relevant to “drive-by-wire” systems in which there are no physical connections, such as throttle cables, between the accelerator pedal and the throttle plate/body. In some applications, there may be additional sensors and devices fitted to act as back-ups should a primary component or sensor fail.
The most common causes of code P0220 could include the following-
- Mal-adjusted TPS sensors
The most common symptoms of code P0220 are much the same on all vehicles, although the severity of some symptoms may vary from vehicle to vehicle. The most common symptoms may include the following-
- Poor acceleration
- Power loss
- Rough idling
NOTE #1: Before starting an electrical diagnosis of code P0220, it is important to check the TPS for correct adjustment. Mechanical wear in the actuating mechanism often causes a deviation from factory settings, which can result in incorrect signals being generated. For instance, the most wear on TPS sensors occur within the first 20% or so of the throttle plates’ travel, meaning that the throttle plate can either “flutter” in this part of its travel, or not close fully. In the latter case, the initial adjustment will not agree with factory specs.
- P0221 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem”
- P0222 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit Low Input”
- P0223 – Relates to “Throttle/Pedal Position Sensor/Switch B Circuit High Input”
I have identify a P0220 code fault on My Kia Sorento 2004. This fault code only comes up when the car pass by a lot of water, and last time when the engine was washed.
Usually what happen is that the Engine Light ON and the rotation remain on 1400 rpm without any acceleration.
After one or two days with the car stopped the problem disappear. It seems a problem of bad isolation of any sensor?????
Do you anyone already experienced this issue and solve it?
