P0210 – Injector 10 -circuit malfunction
P0210 | Injector 10 -circuit malfunction (Buy Part On Amazon) | Wiring, injector, ECM |
- What Does Code P0210 Mean?
- What are the common causes of code P0210 ?
- What are the symptoms of code P0210 ?
- How do you troubleshoot code P0210 ?
- Codes Related to P0210
- Get Help with P0210
A fuel injector
(Courtesy: waynesgarage.com)
The code P0206 stands for Injector 6 – Circuit Malfunction. This means that the PCM had detected a malfunction in this injector circuit. In other words, the PCM commanded the injector on/off but did not see the subsequent change in electrical current.
(Courtesy: justanswer.com)
To sum things up, the common causes for code P0210 are as follows:
- Failed injector
In addition to an illuminated check engine light, symptoms may include: an engine misfire, an engine that stalls and an engine that cranks but doesn’t start. Other codes, such as misfire codes, often accompany code P0210.
The following steps will help you troubleshoot a P0210 code:
Testing with a noid light
(Courtesy: plusquip.com)
(Courtesy: 2carpros.com)
