P0209 – Injector 9 -circuit malfunction
| P0209 | Injector 9 -circuit malfunction (Buy Part On Amazon) | Wiring, injector, ECM |
- What Does Code P0209 Mean?
- What are the common causes of code P0209 ?
- What are the symptoms of code P0209 ?
- How do you troubleshoot code P0209 ?
- Codes Related to P0209
- Get Help with P0209
A fuel injector
(Courtesy: waynesgarage.com)
The code P0206 stands for Injector 6 – Circuit Malfunction. This means that the PCM had detected a malfunction in this injector circuit. In other words, the PCM commanded the injector on/off but did not see the subsequent change in electrical current.
(Courtesy: justanswer.com)
To sum things up, the common causes for code P0209 are as follows:
- Failed injector
In addition to an illuminated check engine light, symptoms may include: an engine misfire, an engine that stalls and an engine that cranks but doesn’t start. Other codes, such as misfire codes, often accompany code P0209.
The following steps will help you troubleshoot a P0209 code:
Testing with a noid light
(Courtesy: plusquip.com)
(Courtesy: 2carpros.com)
Reading P0209 on your car
A basic adapter will show you P0209, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
