P0206 – Injector 6 -circuit malfunction
Mia
By Mia (Contact Me)
Last Updated 2017-08-26
P0206 Injector 6 -circuit malfunction
Wiring, injector, ECM
  1. What Does Code P0206 Mean?
  2. What are the common causes of code P0206 ?
  3. What are the symptoms of code P0206 ?
  4. How do you troubleshoot code P0206 ?
  5. Codes Related to P0206
  6. Get Help with P0206
The days of carburetors are long gone. Electronic fuel injection has been implemented in cars since the 1980s. Fuel injection offers more precise control over the fuel distribution. This results in better economy, better performance and reduced emissions.
One of the main components in a modern fuel system is the fuel injector. When the solenoid inside a fuel injector is energized, it lifts a valve off inside the injector and fuel is sprayed into the engine. Typically, there is always battery power at one of the two injector terminals. When injection is required, the powertrain control module (PCM) driver grounds the other terminal. This completes the circuit and fuel is sprayed into the cylinder.
fuel-injector
A fuel injector
(Courtesy: waynesgarage.com)
The code P0206 stands for Injector 6 – Circuit Malfunction. This means that the PCM had detected a malfunction in this injector circuit. In other words, the PCM commanded the injector on/off but did not see the subsequent change in electrical current.
injector-control-circuit
(Courtesy: justanswer.com)
To sum things up, the common causes for code P0206 are as follows:
  • Failed injector
  • Fault in the injector circuit
  • Problem with the PCM (injector driver)
In addition to an illuminated check engine light, symptoms may include: an engine misfire, an engine that stalls and an engine that cranks but doesn’t start. Other codes, such as misfire codes, often accompany code P0206.
The following steps will help you troubleshoot a P0206 code:
  • Perform a visual inspection of the injectors and connections.
  • Check for misfires with a scan tool
  • Once you’ve determined which cylinder(s) are misfiring, you can troubleshoot the injector circuit for those cylinders. The easiest way to check if the control circuit to the injector is good is by using a noid light. You simply disconnect the injector and insert the light into connector. If the noid light flashes when cranking the engine, the control circuit is functioning properly.
noid-light
Testing with a noid light
(Courtesy: plusquip.com)
If the noid light does not illuminate (or is comes on but doesn’t blink) there is a problem. Either the injector is not properly grounding the circuit, or there is no power to the injector. This can easily be checked using a simple test light. Attach one end of your test light to ground and touch the other to the B+ pin on the injector connector – the tight light should illuminate. If not, consult the factory wiring diagram and repair the power side of the circuit as necessary.
test-light
(Courtesy: 2carpros.com)
test-multimeter
oscilloscope-waveform
oscilloscope-saturated
  • DTC P0201: Injector Circuit – Cylinder 1
  • DTC P0202: Injector Circuit – Cylinder 2
  • DTC P0203: Injector Circuit – Cylinder 3
  • DTC P0204: Injector Circuit – Cylinder 4
  • DTC P0205: Injector Circuit – Cylinder 5
  • DTC P0207: Injector Circuit – Cylinder 7
  • DTC P0208: Injector Circuit – Cylinder 8
  • DTC P0209: Injector Circuit – Cylinder 9
  • DTC P0210: Injector Circuit – Cylinder 10
  • DTC P0211: Injector Circuit – Cylinder 11
  • DTC P0212: Injector Circuit – Cylinder 12
  • DTC P0213: Cold Start Injector 1
  • DTC P0214: Cold Start Injector 2
