P0204 – Injector 4 -circuit malfunction
Last Updated 2017-08-26
P0204 | Injector 4 -circuit malfunction (Buy Part On Amazon) | Wiring, injector, ECM |
What Does Code P0204 Mean?
A fuel injector
(Courtesy: waynesgarage.com)
The code P0204 stands for Injector 4 – Circuit Malfunction. This means that the PCM had detected a malfunction in the fourth injector circuit. In other words, the PCM commanded the injector on/off but did not see the subsequent change in electrical current.
(Courtesy: justanswer.com)
What are the common causes of code P0204 ?
To sum things up, the common causes for code P0204 are as follows:
- Failed injector
What are the symptoms of code P0204 ?
In addition to an illuminated check engine light, symptoms may include: an engine misfire, an engine that stalls and an engine that cranks but doesn’t start. Other codes, such as misfire codes, often accompany code P0204.
How do you troubleshoot code P0204 ?
The following steps will help you troubleshoot a P0204 code:
Testing with a noid light
(Courtesy: plusquip.com)
(Courtesy: 2carpros.com)
Codes Related to P0204
Sr I’m car to not satat to injector to sarvish to Bo boat stay in car to
DF029 dignostic code definition
