P0203 – Injector 3 -circuit malfunction
Last Updated 2017-08-26
P0203 | Injector 3 -circuit malfunction | Wiring, injector, ECM |
What Does Code P0203 Mean?
A fuel injector
(Courtesy: waynesgarage.com)
The code P0203 stands for Injector 3 – Circuit Malfunction. This means that the PCM had detected a malfunction in the third injector circuit. In other words, the PCM commanded the injector on/off but did not see the subsequent change in electrical current.
(Courtesy: justanswer.com)
What are the common causes of code P0203 ?
To sum things up, the common causes for code P0203 are as follows:
- Failed injector
What are the symptoms of code P0203 ?
In addition to an illuminated check engine light, symptoms may include: an engine misfire, an engine that stalls and an engine that cranks but doesn’t start. Other codes, such as misfire codes, often accompany code P0203.
How do you troubleshoot code P0203 ?
The following steps will help you troubleshoot a P0203 code:
Testing with a noid light
(Courtesy: plusquip.com)
(Courtesy: 2carpros.com)
Codes Related to P0203
5 injectors with the key in the on position show 6 volts the bad one shows 12 volts why?
