P0201 – Injector 1 -circuit malfunction
Last Updated 2017-08-26
P0201 | Injector 1 -circuit malfunction (Buy Part On Amazon) | Wiring, injector, ECM |
What Does Code P0201 Mean?
A fuel injector
(Courtesy: waynesgarage.com)
The code P0201 stands for Injector 1 – Circuit Malfunction. This means that the PCM had detected a malfunction in the first injector circuit. In other words, the PCM commanded the injector on/off but did not see the subsequent change in electrical current.
(Courtesy: justanswer.com)
What are the common causes of code P0201 ?
To sum things up, the common causes for code P0201 are as follows:
- Failed injector
What are the symptoms of code P0201 ?
In addition to an illuminated check engine light, symptoms may include: an engine misfire, an engine that stalls and an engine that cranks but doesn’t start. Other codes, such as misfire codes, often accompany code P0201.
How do you troubleshoot code P0201 ?
The following steps will help you troubleshoot a P0201 code:
Testing with a noid light
(Courtesy: plusquip.com)
(Courtesy: 2carpros.com)
Codes Related to P0201
Hi there I have a Astra h vxr 06 reg I recently got it remapped and car cut out on me whilst I’m driving and now does not start at all I have plugged a snap on machine in am getting 4 error code p201,p202,p203,p204 cylinder 1,2,3,4 open cuircuit has anyone ever had this problem before please let me nor thanks
Se tiver GNV o defeito está no emulador de bicos. Ou caso não tenha GNV o defeito está no ponto comum de ligação dos bicos.
I’m having the same issue with my eclipse, but it’s only cylinder 1 open circuit, did you ever figure it out?
