P0200 – Injector -circuit malfunction
Last Updated 2016-07-29
P0200 | Injector -circuit malfunction (Buy Part On Amazon) | Wiring, injector, ECM |
What Does Code P0200 Mean?
A fuel injector
(Courtesy: waynesgarage.com)
The code P0200 stands for Injector Circuit Malfunction. This means that the PCM had detected a malfunction in one of the injector circuits. In other words, the PCM commanded the injector on/off but did not see the subsequent change in electrical current.
(Courtesy: justanswer.com)
What are the common causes of code P0200?
To sum things up, the common causes for code P0200 are as follows:
- Failed injectors
What are the symptoms of code P0200?
In addition to an illuminated check engine light, symptoms may include: an engine misfire, an engine that stalls and an engine that cranks but doesn’t start. Other codes, such as misfire codes, often accompany code P0200.
How do you troubleshoot code P0200?
The troubleshooting information listed here can also be applied to codes P0201-P0214. The only difference is these codes are for injectors on particular cylinders. So, if you have a cylinder specific injector circuit code, you can skip the second step on the list. The following steps will help you troubleshoot a P0200 code:
Testing with a noid light
(Courtesy: plusquip.com)
(Courtesy: 2carpros.com)
Codes Related to P0200
Am orphan looking for someone who can nature me,to be perfect with my job. To be advanced
Olá estou com uma Reno master 2.
3
código de falha p0200-28 tem pulso e pressão de combustível mas não pega alguém já pegou por favor
I have a 2008 Rav4 D-4D. I have followed the steps 1-4 to test for power to injectors. When I test power with volt meter I get a ridiculously high voltage of 86.4. I have test with more than 1 tester and get same reading – tried a test light and this obviously exploded (melted globe) what is the cause of this reading? I have test injectors and they all fine per specifications but have not yet removed
Thanks for the answer you gave. Can you offer me a full couse electrical and electronic
