P0189 – Fuel temperature sensor B -circuit intermittent
Last Updated 2016-06-03
P0189 | Fuel temperature sensor B -circuit intermittent (Buy Part On Amazon) | Wiring, poor connection, fuel temperature sensor, ECM |
What Does Code P0189 Mean?
The ECM continually monitors the resistance of the FTS, calculating temperature based on those readings. If there is a fault in the FTS or FTS circuit, the ECM will illuminate the malfunction indicator lamp (MIL) and set a diagnostic trouble code (DTC) in memory. Specifically, if the ECM detects a temperature change in excess of ±10 °C (±18 °F) / 100 ms, it interprets this as an intermittent circuit fault, setting DTC P0189 – “Fuel Temperature Sensor “B” Circuit Intermittent.”
Note: Regardless of the code and the system affected, the word “Intermittent” refers to the fact that there is a sporadic, unpredictable, or, well, intermittent fault in that system. The most likely causes of codes that relate to intermittent faults include poor connections in both live and ground circuits, as well defective switches, relays, and sensors.
What are the common causes of code P0189 ?
DTC P0189 may have number of causes:
What are the symptoms of code P0189 ?
How do you troubleshoot code P0189 ?
Keep in mind that this is an intermittent fault, which could range from something as simple as a loose connection to a temperature-related open circuit in the wiring harness or FTS itself, perhaps even in the ECM. Intermittent faults can be difficult to pin down, and may require multiple tests to firmly identify and repair. Be patient and methodical to have the best chance of success.
Codes Related to P0189
- DTC P0183 Fuel Temperature Sensor A Circuit High Input
- DTC P0184 Fuel Temperature Sensor A Circuit Intermittent
