P0188 – Fuel temperature sensor B -high input
Last Updated 2016-06-03
P0188 | Fuel temperature sensor B -high input (Buy Part On Amazon) | Wiring short to positive, fuel temperature sensor, ECM |
What Does Code P0188 Mean?
The ECM continually monitors the resistance of the FTS, calculating temperature based on those readings. If there is a fault in the FTS or FTS circuit, the ECM will illuminate the malfunction indicator lamp (MIL) and set a diagnostic trouble code (DTC) in memory. When P0188 is set, the PCM has determined that the input voltage from fuel temp sensor B is higher than the calibrated limit indicating a lower than normal temperature.
What are the common causes of code P0188 ?
DTC P0188 may have number of causes:
What are the symptoms of code P0188 ?
How do you troubleshoot code P0188 ?
Codes Related to P0188
- DTC P0183 Fuel Temperature Sensor B Circuit High Input
