P0186 – Fuel temperature sensor B -range/performance problem
Last Updated 2016-06-03
P0186 | Fuel temperature sensor B -range/performance problem | Fuel temperature sensor |
What Does Code P0186 Mean?
The ECM continually monitors the resistance of the FTS, calculating temperature based on those readings. If there is a fault in the FTS or FTS circuit, the ECM will illuminate the malfunction indicator lamp (MIL) and set a diagnostic trouble code (DTC) in memory. When P0186 is set, the PCM has determined that the input voltage from fuel temp sensor B is out of the normal range. The vehicle has 2 fuel temperature sensors, and the “B” sensor is out of range.
Note: A Range/Performance related code will be set when either a sensor or other component does not perform within the range the PCM (Powertrain Control Module) expects to see, given the current engine load/speed, and information gathered from other sensors. The possible causes of Range/Performance codes are likely to be defective sensors as easily as they are likely to be the result of wiring issues that affect the operation of the affected sensor or component, which means that with these codes, it is important to regard all sensors and components as part of the control circuit the code refers to.
What are the common causes of code P0186 ?
DTC P0186 may have number of causes:
What are the symptoms of code P0186 ?
How do you troubleshoot code P0186 ?
Codes Related to P0186
- DTC P0183 Fuel Temperature Sensor A Circuit High Input
