P0185 – Fuel temperature sensor B -circuit malfunction
P0185 | Fuel temperature sensor B -circuit malfunction (Buy Part On Amazon) | Wiring, fuel temperature sensor, ECM |
- What Does Code P0185 Mean?
- What are the common causes of code P0185 ?
- What are the symptoms of code P0185 ?
- How do you troubleshoot code P0185 ?
- Codes Related to P0185
- Get Help with P0185
The ECM continually monitors the resistance of the FTS, calculating temperature based on those readings. If there is a fault in the FTS or FTS circuit, the ECM will illuminate the malfunction indicator lamp (MIL) and set a diagnostic trouble code (DTC) in memory. When P0185 is set, the PCM has determined that there is a problem in the fuel temperature circuit. Sensor B indicates that this vehicle has two fuel temperature sensors, and that the “B” sensor has the malfunction.
DTC P0185 may have number of causes:
- DTC P0183 Fuel Temperature Sensor A Circuit High Input
