P0184 – Fuel temperature sensor A -circuit intermittent
Benjamin Jerew
Last Updated 2016-06-03
P0184 Fuel temperature sensor A -circuit intermittent
Wiring, poor connection, fuel temperature sensor, ECM
  1. What Does Code P0184 Mean?
  2. What are the common causes of code P0184 ?
  3. What are the symptoms of code P0184 ?
  4. How do you troubleshoot code P0184 ?
  5. Codes Related to P0184
  6. Get Help with P0184
The ECM continually monitors the resistance of the FTS, calculating temperature based on those readings. If there is a fault in the FTS or FTS circuit, the ECM will illuminate the malfunction indicator lamp (MIL) and set a diagnostic trouble code (DTC) in memory. Specifically, if the ECM detects a temperature change in excess of ±10 °C (±18 °F) / 100 ms, it interprets this as an intermittent circuit fault, setting DTC P0184 – “Fuel Temperature Sensor “A” Circuit Intermittent.”
2008-10-07_195305_fuel_temp_sensor
Note: Regardless of the code and the system affected, the word “Intermittent” refers to the fact that there is a sporadic, unpredictable, or, well, intermittent fault in that system. The most likely causes of codes that relate to intermittent faults include poor connections in both live and ground circuits, as well defective switches, relays, and sensors.
DTC P0184 may have number of causes:
  • Electrical Short Circuit or Open Circuit – Wiring problems are usually the biggest problem affecting the FTS. Water entry, corrosion, and wire harness damage can all cause intermittent problems in the FTS-ECM circuit.
  • Faulty Fuel Temperature Sensor or ECM – Neither of these is “common,” but that doesn’t mean they cannot fail. The FTS itself is a fairly bulletproof solid-state thermistor, and therefore isn’t a common failure point. The ECM, similarly, isn’t prone to failure, but can be induced by other problems, such as water entry or collision damage.
fuel heater
  • From the ECM side of the circuit, turn the key off and disconnect the ECM.
    • Confirm pins are straight and that there is no evidence of corrosion or water intrusion. Clean or repair as necessary.
    • Check for proper resistance across the two pins. At this point, because you are looking for an intermittent connection, you may measure proper resistance, according to the chart in the repair manual, or an open- or short-circuit.
      • You may need to follow the wire harness and give it a good shake, that is, flex it and shake it to induce the failure. If resistance changes suddenly, then you have a problem in the wire harness. Repair as necessary.
    • If the shake test doesn’t reveal a problem in the wire harness, then proceed to testing the FTS and its connector.
      • Again, check for bent pins or the presence of corrosion or water intrusion. Repair as necessary.
      • With the FTS disconnected, you should read an open-circuit from the ECM connector. Otherwise, find and repair the short-circuit in the wire harness.
      • With a short pin installed in the FTS connector, you should read a short-circuit from the ECM connector. Otherwise, find and repair the open circuit in the wire harness.
    • Test the resistance of the FTS directly. Measure the resistance of the FTS and compare it to the chart in the repair manual.
      • If the FTS resistance measures outside the expected range, replace it.
      • If you can confirm the circuit has no faults, replace the sensor.
  • From the FTS, if it is easier to access first, check the connector for bent pins of corrosion, then reconnect firmly, turn the key on and back-probe the FTS connector. Check for 5 V reference voltage coming from the ECM, and a lower signal voltage coming from the FTS. While testing, you may need to shake and twist the wiring harness to induce the failure.
    • If you don’t see 5 V coming from the ECM, suspect an open-circuit in the wire from the ECM or a short-circuit or short-to-ground in the wiring harness before the FTS. Find and repair as necessary.
    • If you see 5 V reference, but no signal voltage, suspect a fault in the FTS. Replace as necessary.
    • If you see 5 V on the signal line, suspect an open-circuit in the signal line to the ECM, short-circuit to the reference line from the ECM, or a short-to-ground in the signal line before the ECM. Repair as necessary.
Keep in mind that this is an intermittent fault, which could range from something as simple as a loose connection to a temperature-related open circuit in the wiring harness or FTS itself, perhaps even in the ECM. Intermittent faults can be difficult to pin down, and may require multiple tests to firmly identify and repair. Be patient and methodical to have the best chance of success.
47680_x800
  • DTC P0176 Fuel Composition Sensor Circuit Malfunction
  • DTC P0177 Fuel Composition Sensor Circuit Range/Performance
  • DTC P0178 Fuel Composition Sensor Circuit Low Input
  • DTC P0179 Fuel Composition Sensor Circuit High Input
  • DTC P0180 Fuel Temperature Sensor A Circuit Malfunction
  • DTC P0181 Fuel Temperature Sensor A Circuit Range/Performance
  • DTC P0182 Fuel Temperature Sensor A Circuit Low Input
  • DTC P0183 Fuel Temperature Sensor A Circuit High Input
  • DTC P0185 Fuel Temperature Sensor B Circuit Malfunction
  • DTC P0186 Fuel Temperature Sensor B Circuit Range/Performance
  • DTC P0187 Fuel Temperature Sensor B Circuit Low Input
  • DTC P0188 Fuel Temperature Sensor B Circuit High Input
  • DTC P0189 Fuel Temperature Sensor B Circuit Intermittent
