P0183 – Fuel temperature sensor A -high input
| P0183 | Fuel temperature sensor A -high input (Buy Part On Amazon) | Wiring short to positive, fuel temperature sensor, ECM |
- What Does Code P0183 Mean?
- What are the common causes of code P0183 ?
- What are the symptoms of code P0183 ?
- How do you troubleshoot code P0183 ?
- Codes Related to P0183
- Get Help with P0183
The ECM continually monitors the resistance of the FTS, calculating temperature based on those readings. If there is a fault in the FTS or FTS circuit, the ECM will illuminate the malfunction indicator lamp (MIL) and set a diagnostic trouble code (DTC) in memory. When P0183 is set, the PCM has determined that the input voltage from fuel temp sensor A is higher than the calibrated limit indicating a lower than normal temperature.
DTC P0183 may have number of causes:
Reading P0183 on your car
A basic adapter will show you P0183, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
Solution of p0183 beat chevrolet
Fuel filter body change krdo
Posible solution for the Trouble code P0183
Man falt Kya hai
