P0180 – Fuel temperature sensor A -circuit malfunction
Last Updated 2016-06-03
P0180 | Fuel temperature sensor A -circuit malfunction | Wiring, fuel temperature sensor, ECM |
What Does Code P0180 Mean?
The ECM continually monitors the resistance of the FTS, calculating temperature based on those readings. If there is a fault in the FTS or FTS circuit, the ECM will illuminate the malfunction indicator lamp (MIL) and set a diagnostic trouble code (DTC) in memory. When P0180 is set, the PCM has determined that there is a problem in the fuel temperature circuit.
What are the common causes of code P0180 ?
DTC P0180 may have number of causes:
What are the symptoms of code P0180 ?
How do you troubleshoot code P0180 ?
Codes Related to P0180
- DTC P0183 Fuel Temperature Sensor A Circuit High Input
where is the fuel temperature sensor in 1999 nissan maxima
I had that code P0180 but no one could identify it as what to replace complete fuel pump or just a Fuel temperature sensor on the bottom of the page? Is there ea p/n Thanks for help!
Janni-
It really depends on where the fuel temperature sensor is located and whether it’s even available separately. I would be more suspect of the wiring going to the sensor than of the sensor itself. Faulty sensors are not that common, especially if you don’t have a current code. Intermittent problems can be a pain to track down, but a momentary disconnection because of a loose connector or something like that can set the code and still make it impossible to diagnose.
where is fuel temperature sensor located in 2003 Kia optima lx, please i need your help
