P0174 – System too lean, bank 2
Last Updated 2017-11-02
P0174 | System too lean, bank 2 | Intake/exhaust leak, fuel pressure/pump, injector(s), AIR system, hose connection(s) |
What Does Code P0174 Mean?
The long term fuel trim and the short term fuel trim provide essential diagnostic data for diagnosing engine problems. In fact, a scan tool reading of the long term fuel trim can lead to a quick fix of a P0174 or P0171 code.
Fuel trims are settings which control the amount of fuel entering the engine to achieve a stoichiometric ratio of 14.7:1. The stoichiometric ratio is the volume mixture of air and fuel that will result in complete combustion of the fuel and oxygen. The car’s computer control will always seek 14.7 liters of air for each liter of gasoline. It is important to remember this fundamental law for your car.
Since the stoichiometric ratio is very important to engine performance, there are multiple air sensors and fuel controls that measure the air and fuel entering your car’s engine. The most common sensors are the Mass Air Flow sensor (MAF), the Intake Air Temperature sensor (IAT), Manifold Air Pressure sensor (MAP), the Short Term Fuel Trim (STFT), the Long Term Fuel Trim (LTFT), and the Oxygen sensor (02). A few examples will explain the interaction of these sensors and their role in engine diagnosis.
What are the common causes of code P0174 ?
Unmetered air entering the engine is a common cause of the P0174 trouble code. While the air passing through the MAF sensor is metered by the car computer, intake leaks or vacuum leaks are not known. These sources of additional air increase the air to fuel mixture. A quick way to detect a leak is to observe the LTFT readings at idle and full throttle. At full throttle, a small leak will contribute far less air to the large overall volume of air entering the engine.
A lean condition, which can lead to the P0174 trouble code, is much more common than a rich condition. A lean condition is detected when the O2 sensor responds to the presence of oxygen by inhibiting its voltage output. Said another way, an oxygen sensor will produce an output of 1 Volt if the exhaust mixture does not contain oxygen. A typical 02 sensor reading for a lean condition will be much lower than 1 Volt as shown below.
When the car computer detects a lean condition in the O2 sensor, it will immediately try to correct the lean condition and return to the stoichiometric ratio by adding fuel. Enter your short term fuel trim (STFT). The short term fuel trim is a percentage change in fuel delivered to the engine. For a lean condition, more fuel is required, and the short term fuel trim will be positive anywhere between 0 and 50%. The short term fuel trim increases until the oxygen sensor tells the computer that the stoichiometric ratio of 14.7 exists. Once the engine is back in stoichiometric balance, the short term fuel trim will level out. Now enter your long term fuel trim (LTFT). The LTFT will be set at the STFT setting. The LTFT takes over for the STFT (which will return to zero after the LTFT memorizes the STFT setting) to keep the engine in stoichiometric ratio.
What causes the P0174 code? Generally, if the LTFT is above 25% for two driving cycles, the computer will throw the P0174 code.
What are the symptoms of code P0174 ?
The lean condition should disappear at full throttle, but be noticeable at idle if there is a small vacuum leak.
Codes Related to P0174
P0171 is the bank 1 version of this same code.
BAT Team Discussions for P0174
- 2001 ford windstar DTC P0171
Is the P0171 the only code you are getting?? If so, these TSBs are not likely much help. 01-20-5 is an informational bulletin regarding the use of Rotunda's Vacutec 522 - Smoke Leak Detector Machine to help detect vacuum or air leaks in the engine compartment air intake or vacuum system. 03-16-1 i... - cold starts chevy k2500hd
Hello, I am the original owner of my k2500 HD. I'm an auto body and frame tech, so I'm somewhat knowledgable mechanically, and maintain my own vehicles. Truck is as follows 6.0 engine, 4L80 e trans, 4.10 rr axle. Mods are a K&N fipk2 installed at 25,000 mi, throttle body spacer installed at 25,... - 2004 Taurus DOHC 3.0 V6 Acceleration Stumble/Hesitation
The only really common thing we see on fords in the shop are the vacuum lines to the pcv mainly get all mushy and gooey. They leak vacuum and cause rough idling and in more extreme cases stalling. the check engine light does come on eventually and the code is p0174 or p0171 or both. We have not had ... - 1995 & 1997 Crown Victoria P71 cars
Hi, all! My wife bid on (and got) 2 ex-police units at auction. They were inexpensive enough, one is an ex-black & white, the other was an undercover car. I was surprised to find the 1995 had OBD-II, but that was just a plus. The black & white has no problems, but I have been getting a code P017... - 2000 Taurus SE - P1174/1131/1151/171errors
Vin code digit #8 is "U". I did screw up on the codes...P0174=fuel trim system lean bank 2 and P0171=fuel trim system lean bank 1. The P1151 and P1131 were correct codes. Our initial thought is to put in a fuel pump but hate to and find that was not the issue, would think a fuel pump would also p...
got this code after installing a coolant temperature sensor on 2005 kia sportage lx w/ 2.7l
I received this code after installing a 1000 cm air intake….think it could be related? Hahahha
Replaced my MAF sensor and the wire pigtail and began getting P0102 error code in my 2002 E39 BMW 530i indicating air flow sensor low circuit voltage. I figured this had to do with the but connected tictail I installed causing a voltage drop between the air sensor and ECU module therefore I removed the butt connector connection and soldered in another pig tail connector. However I continue to get the same error code. I am starting to believe possibly I have a faulty MAF sensor right out the box. Any advice or suggestions would be greatly appreciated, thanks in advance.
Rick Martin II
