P0167 – Heated oxygen sensor (HO2S) 3, bank 2, heater control circuit malfunction
Last Updated 2015-11-25
P0167 | Heated oxygen sensor (HO2S) 3, bank 2, heater control circuit malfunction (Buy Part On Amazon) | Wiring, HO2S, ECM |
What Does Code P0167 Mean?
Code P0167 stands for HO2S heater Performance Bank 2 Sensor 3. This indicates the PCM has detected a problem with heater circuit of the downstream oxygen sensor. Bank 2 refers to the side of the engine opposite of the #1 cylinder. If you’ve got a four-cylinder, there will only be one bank, and you would not get this code. The related code for Bank 1 is P0147 HO2S Heater Performance Bank 1 Sensor 3. This indicates the PCM has detected a problem with the bank 1 downstream oxygen sensor heater.
Oxygen sensor diagram
(Courtesy: samarins.com)
What are the common causes of code P0167 ?
To sum things up, the common causes for code P0167 are as follows:
What are the symptoms of code P0167 ?
How do you troubleshoot code P0167 ?
(Courtesy: alldata.com)
(Courtesy: 2carpros.com)
Codes Related to P0167
DTC P0030: HO2S Heater Control Circuit Bank 1 Sensor 1
DTC P0036: HO2S Heater Control Circuit Bank 1 Sensor 2
DTC P0053: HO2S Heater Resistance Circuit Bank 1 Sensor 1
DTC P0054: HO2S Heater Resistance Circuit Bank 1 Sensor 2
DTC P0050: HO2S Heater Control Bank 2 Sensor 1
DTC P0056: HO2S Heater Control Bank 2 Sensor 2
DTC P0059: HO2S Heater Resistance Bank 2 Sensor 1
DTC P0060: HO2S Heater Resistance Bank 2 Sensor 2
DTC P0135: HO2S Heater Performance Bank 1 Sensor 1
DTC P0141: HO2S Heater Performance Bank 1 Sensor 2
DTC P0155: HO2S Heater Performance Bank 2 Sensor 1
DTC P0147: HO2S Heater Performance Bank 1 Sensor 3
