P0163 – Heated oxygen sensor (HO2S) / Oxygen sensor (O2S) 3, bank 2 -low voltage
Benjamin Jerew
Last Updated 2016-07-05
P0163 Heated oxygen sensor (HO2S) 3, bank 2 -low voltage
Exhaust leak, wiring short to earth, HO2S, ECM
  1. What Does Code P0163 Mean?
  2. What are the common causes of code P0163 ?
  3. What are the symptoms of code P0163 ?
  4. How do you troubleshoot code P0163 ?
  5. Codes Related to P0163
  6. Get Help with P0163
a3iCrSK57hVSreQz1Met7hdf
po420_fig06
  • DTC P0163 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 3 (B2S3)
For reference, Bank 1 and Bank 2 refer to which bank of cylinders, left or right if it’s a V configuration, Bank 1 containing Cylinder 1. Inline engines may be divided, Bank 1 being Cylinder 1 & 2 or 1 – 3. Sensor 1 or Sensor 2 refers to the sensor’s position before or after the TWC. Sensor 1 is before the TWC and Sensor 2 is after the TWC.  Sensor 3 refers to the 2nd oxygen sensor that is located downstream of the catalytic converter on some V8 and V10 and V12 engines.
Depending on year, make, and model, DTC P0163 may have number of causes. Here are some of the most common.
  • HO2S Fault – The most common failure is a fault in the sensor itself. Constantly exposed to the elements and to the heat of exhaust, HO2S has a typical lifespan of less than 5 years.
  • Circuit Fault – Because they are exposed to the elements, wire harnesses, connectors, and the sensor itself may be physically damaged by impact or road debris. Water entry and corrosion are common faults.
SS.1466533733
  • General Checks – First, check fuses and harnesses for any obvious problems, such as blown fuses and chafed or pinched wires. Check the oxygen sensors for damage. Check the connectors for bent or broken pins or corrosion and that they are properly seated. Repair as necessary.
  • Exhaust Check – As a matter of course, use an open mechanic’s stethoscope to check for exhaust leaks, particularly between the TWC and HO2S. Repair as necessary.
  • Circuit Checks – Disconnect the ECM and HO2S. Check for continuity on the two lines. You should have less than 1 Ω resistance end to end and more than 10 kΩ between them and to ground.
    • If you find excessive resistance or a short circuit, repair as necessary.
    • If resistance is proper, replace the sensor.
  • Sensor – Generally, most people simply jump to replacing the sensor, though you shouldn’t condemn the sensor unless you can rule out circuit problems.
    • Check the HO2S for internal resistance. From the heater positive to both sides of the sensor circuit should measure over 10 kΩ. Replace if otherwise.
    • If you can view live data from the HO2S and AFR sensor, compare the two signals. If the HO2S is stuck low or high, you can safely assume a faulty sensor. If you have active testing, even better, as you can attempt to force an HO2S reaction. If you get no response, suspect a sensor or circuit fault.
SS.1466611588
  • P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
  • P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
  • P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
  • P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
  • P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
  • P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
  • P0150 O2 Sensor Circuit (Bank 2 Sensor 1)
  • P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
  • P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
  • P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
  • P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
  • P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
  • P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
  • P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
  • P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
