P0161 – Heated oxygen sensor (HO2S) 2, bank 2, heater control -circuit malfunction
Last Updated 2015-11-25
P0161 | Heated oxygen sensor (HO2S) 2, bank 2, heater control -circuit malfunction (Buy Part On Amazon) | Wiring, HO2S, ECM |
What Does Code P0161 Mean?
Code P0161 stands for HO2S heater Performance Bank 2 Sensor 2. This indicates the PCM has detected a problem with heater circuit of the downstream oxygen sensor. Bank 2 refers to the side of the engine opposite the #1 cylinder. If you’ve got a four-cylinder, there will only be one bank, and you would not get this code. The related code for the other bank is P0141 HO2S Heater Performance Bank 1 Sensor 2. This indicates the PCM has detected a problem with the bank 1 downstream oxygen sensor heater.
Oxygen sensor diagram
(Courtesy: samarins.com)
What are the common causes of code P0161 ?
To sum things up, the common causes for code P0161 are as follows:
What are the symptoms of code P0161 ?
How do you troubleshoot code P0161 ?
(Courtesy: alldata.com)
(Courtesy: 2carpros.com)
Codes Related to P0161
DTC P0030: HO2S Heater Control Circuit Bank 1 Sensor 1
DTC P0036: HO2S Heater Control Circuit Bank 1 Sensor 2
DTC P0053: HO2S Heater Resistance Circuit Bank 1 Sensor 1
DTC P0054: HO2S Heater Resistance Circuit Bank 1 Sensor 2
DTC P0135: HO2S Heater Performance Bank 1 Sensor 1
DTC P0141: HO2S Heater Performance Bank 1 Sensor 2
DTC P0050: HO2S Heater Control Bank 2 Sensor 1
DTC P0056: HO2S Heater Control Bank 2 Sensor 2
DTC P0059: HO2S Heater Resistance Bank 2 Sensor 1
DTC P0060: HO2S Heater Resistance Bank 2 Sensor 2
DTC P0155: HO2S Heater Performance Bank 2 Sensor 1
DTC P0167: HO2S Heater Performance Bank 2 Sensor 3
my toyota highlander check engine light came up, fuel consumption became terrible, now my car burns oil 1Liter every 4days.. no oil leakage on the ground. help anyone?
Tboss-
I would say you’ve got more problems than just a burnt-out oxygen sensor. From the sound of it, I would say you have a sludged engine.
