P0158 – Heated oxygen sensor (H02S) / oxgen sensor (O2S) 2, bank 2, -high voltage
Last Updated 2016-06-22
P0158 | Heated oxygen sensor (h025) 2, bank 2, -high voltage (Buy Part On Amazon) | Wiring short to positive, HO2S, ECM |
What Does Code P0158 Mean?
- DTC P0158 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2 (B2S2)
What are the common causes of code P0158 ?
Depending on year, make, and model, DTC P0158 may have number of causes. Here are some of the most common.
What are the symptoms of code P0158 ?
How do you troubleshoot code P0158 ?
Codes Related to P0158
My grandson was given a 2000 Chrysler LHS, 3.5 has about 160.000.The last person that had it was my son in law.He wasn’t very much of a mechanic and didn’t want fix cars the right way.So he gave this junk to my Grandson,we have put quite a bit of money in to it and it still has problems.Got rid of some codes by tuning up the engine,spark plugs,pcv valve and air cleaner.had to pay a mechanic to loosen the screws on the coils on each spark plug.Last person that changed plugs likes to tighten everything with all his might.So those code out of the way now we have P0158 & P0172. Some information i see gives us a list of things to check.I think we/ll have to take it to a mechanic and its going to cost.Got any suggestions?
Ruben-
We’ve just gotten up a DIY troubleshooting article that might help you out.
Usually, as long as their isn’t any damage to the wiring, and given the age and mileage of the vehicle, I think you could probably replace the oxygen sensor as a matter of course, keeping in mind this is Bank 2 Sensor 2, that is, the oxygen sensor after the cat on the left side of the engine (right side or passenger side of the vehicle as you’re sitting in it).
I hope this helps.
