P0157 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 2, bank 2 -low voltage
P0157 | Heated oxygen sensor (HO2S) 2, bank 2 -low voltage (Buy Part On Amazon) | Exhaust leak, wiring short to earth, H028, ECM |
- What Does Code P0157 Mean?
- What are the common causes of code P0157 ?
- What are the symptoms of code P0157 ?
- How do you troubleshoot code P0157 ?
- Codes Related to P0157
- Get Help with P0157
- DTC P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2 (B2S2)
Depending on year, make, and model, DTC P0157 may have number of causes. Here are some of the most common.
