P0155 – Heated oxygen sensor (HO2S) 1, bank 2, heater control circuit malfunction
Last Updated 2015-11-23
P0155 | Heated oxygen sensor (HO2S) 1, bank 2, heater control circuit malfunction (Buy Part On Amazon) | Wiring, H028, ECM |
What Does Code P0155 Mean?
The upstream oxygen sensor (O2S) is located ahead of the catalytic converter. It is used to determine the concentration of oxygen in the exhaust gas. This information is used by the PCM to control the engine air/fuel mixture. The sensor compares amount of oxygen in the exhaust to the surrounding air (there is an opening in the sensor that is exposed to the atmosphere). It generates a corresponding voltage which is transmitted to the PCM. The PCM then controls injector pulse based on this value.
Modern vehicles use a heated oxygen sensor (HO2S). These sensors contain a heating element that brings the sensor to operating temperature faster. This allows the PCM to use the signals input sooner, for more precise fuel control and reduced emissions. The heater circuit is energized through a relay that closes when the engine is cranked. The PCM monitors the heater circuit and will turn on the check engine light if it finds a problem.
Code P0155 stands for Oxygen O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1). This indicates the PCM has detected a problem with the bank 2 oxygen sensor. Bank 1 refers to the side of the engine that has the #1 cylinder. Bank 2 is the opposite side of the engine. If you’ve got a four-cylinder, there will only be one bank, and you would not get this code.
A typical heated oxygen sensor
(Courtesy: easterncatalytic.com)
What are the common causes of code P0155 ?
To sum things up, the common causes for code P0155 are as follows:
What are the symptoms of code P0155 ?
In theory, a failed O2 heater will result in poor fuel economy. But you’ll probably never notice the difference during operation. The only thing you will notice is an illuminated check engine light on your dashboard. If your registration is due, you will also fail the emissions test.
How do you troubleshoot code P0155 ?
(Courtesy: alldata.com)
(Courtesy: 2carpros.com)
Codes Related to P0155
Code P0135 is the most closely related code to P0155. It stands for 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1). So, it is essentially the same code, but for the opposite bank of the engine. All of the same diagnostic steps apply.
I have an 03 avalon. It went tru heavy rain after thu lights came on. The code was P0155. How safe is it to still drive the car. And how expensive is it to fix. Other than that the car runs great. Thank you.
