P0152 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 1, bank 2 – – -high voltage
Last Updated 2016-07-05
P0152 | Heated oxygen sensor (HO2S) 1, bank 2 - - -high voltage | Wiring short to positive, H028, ECM |
What Does Code P0152 Mean?
- DTC P0152 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1 (B2S1)
What are the common causes of code P0152 ?
Depending on year, make, and model, DTC P0152 may have number of causes. Here are some of the most common.
What are the symptoms of code P0152 ?
How do you troubleshoot code P0152 ?
Codes Related to P0152
BAT Team Discussions for P0152
- 2001 dodge dakota please help....
Ladies, Gents... I am a Navy guy and trying to fix my 2001 Dakota quadcab 4x4 5.9L. The trans went out so I got it replaced. Then it was great for awhile and the started getting harder to start as the days went by. Checked codes and got p0123 and p0351 and p0152. I smelled sulpher smell so I gutted... - 08' Chevy Avalanche check engine light on with decreased gas milage
More detailed information... DTC P1174 or P1175 Diagnostic Instructions - Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. - Review Strategy Based Diagnosis for an overview of the diagnostic approach. - Diagnostic Procedure Instructions provides an ... - 2010 Cadillac SRx code P0641
i have a 2010 SRX 3.0 V6, 35K miles. I went to pick it up at the airport and it started and barely ran. It was like a car with a massive vacuum leak. The engine would barely idle and if you stepped on the gas nothing happened. Sometimes it would rev a little but then go back to a very low lopey idle... - 2002 Toyota RAV4 - Air-Fuel Sensor Issue Persists & Other Lingering Issues- Need Advice Or Opinion?
@ kev2 & nickb2 & anyone else: Hello. First, to answer kev2's question, the sensor is set to be delivered middle of next week I am told from my sources. So I am patiently waiting for it. I appreciate all the information you have given me. Yes, shortly when I get some free time, I will try some mor...
