P0151 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 1 , bank 2 -low voltage
Last Updated 2016-07-05
P0151 | Heated oxygen sensor (HO2S) 1 , bank 2 -low voltage | Exhaust leak, wiring short to earth, H028, ECM |
What Does Code P0151 Mean?
- DTC P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1 (B2S1)
What are the common causes of code P0151 ?
Depending on year, make, and model, DTC P0151 may have number of causes. Here are some of the most common.
What are the symptoms of code P0151 ?
How do you troubleshoot code P0151 ?
Codes Related to P0151
BAT Team Discussions for P0151
- 1997 CHEVROLET SILVERADO COLD START PROBELM
OK Here we go first thing in the morning got my fuel pressure gauge with one the reaches to the windshield so I could monitor the pressure at different speeds and loads. Here is what I got First start cold n the morning 53-55 psi no more. I did what I mention above to starts the engine and the read... - o2 sensor
Yes , same truck with trans change. Code p0151, The fuse is under hood,indicated as ENG 1. I've been under the truck twice for quite some time checking wires and harnesses. I thought I found it today, found a wire that runs through a metal loom on right side of engine. Isolated wire and made sure it... - P0420 97 ranger
what we want to look at is ox ygen sensors o2, locations s1 and s2 - if there is a 0volt reading on both (should be moving and @.2 to .9) might want to inspect o2 senssor wiring- pluged in damaged etc... definately a reason to suspect sensor BUT both failing at same time unlikely.....as the sy... - 08' Chevy Avalanche check engine light on with decreased gas milage
More detailed information... DTC P1174 or P1175 Diagnostic Instructions - Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. - Review Strategy Based Diagnosis for an overview of the diagnostic approach. - Diagnostic Procedure Instructions provides an ... - 2010 Cadillac SRx code P0641
[b]! A/C refrigerant sensor[/b] The codes p0131 & P0151 only came up after letting it run for about 20 minutes while I checked wires, watched it die and restarted etc. I think it was running so bad it was getting a lean signal. Same with the P0300 misfire.Of course it is just out of warranty.51 mon...
