P0147 – Heated oxygen sensor (HO2S) 3, bank 1, heater control circuit malfunction
Mia
By Mia (Contact Me)
Last Updated 2015-11-25
P0147 Heated oxygen sensor (HO2S) 3, bank 1, heater control circuit malfunction
Wiring, H028, ECM
  1. What Does Code P0147 Mean?
  2. What are the common causes of code P0147 ?
  3. What are the symptoms of code P0147 ?
  4. How do you troubleshoot code P0147 ?
  5. Codes Related to P0147
  6. Get Help with P0147
Code P0147 stands for HO2S heater Performance Bank 1 Sensor 3. This indicates the PCM has detected a problem with heater circuit of the downstream oxygen sensor. Bank 1 refers to the side of the engine that has the #1 cylinder. Bank 2 is the opposite side of the engine. If you’ve got a four-cylinder, there will only be one bank. The related code for the other bank is P0167 HO2S Heater Performance Bank 2 Sensor 3. This indicates the PCM has detected a problem with the bank 2 downstream oxygen sensor heater.
oxygen-sensor-diagram
Oxygen sensor diagram
(Courtesy: samarins.com)
To sum things up, the common causes for code P0147 are as follows:
  • Problem on the ground side of the O2 sensor heater circuit
  • Problem on the power side of the O2 sensor heater circuit
  • O2 sensor heater element has high resistance
  • O2 sensor heater element has an open circuit
02-sensor-heater
(Courtesy: alldata.com)
  • Test the heater circuit wiring
  • Test the sensor heating element
02-heater-resistance
(Courtesy: 2carpros.com)
DTC P0030: HO2S Heater Control Circuit Bank 1 Sensor 1
DTC P0036: HO2S Heater Control Circuit Bank 1 Sensor 2
DTC P0053: HO2S Heater Resistance Circuit Bank 1 Sensor 1
DTC P0054: HO2S Heater Resistance Circuit Bank 1 Sensor 2
DTC P0135: HO2S Heater Performance Bank 1 Sensor 1
DTC P0141: HO2S Heater Performance Bank 1 Sensor 2
DTC P0050: HO2S Heater Control Bank 2 Sensor 1
DTC P0056: HO2S Heater Control Bank 2 Sensor 2
DTC P0059: HO2S Heater Resistance Bank 2 Sensor 1
DTC P0060: HO2S Heater Resistance Bank 2 Sensor 2
DTC P0155: HO2S Heater Performance Bank 2 Sensor 1
DTC P0167: HO2S Heater Performance Bank 2 Sensor 3
