P0144 – Heated oxygen sensor(H02S) / oxgen sensor (O2S) 3, bank 1 -high voltage
| P0144 | Heated oxygen sensor(H025) 3, bank 1 -high voltage (Buy Part On Amazon) | Wiring short to positive, H025, ECM |
Where is the Oxygen Sensor? See our guide to the Oxygen Sensor – what it does, where it sits on the engine and how it fails.
- What Does Code P0144 Mean?
- What are the common causes of code P0144 ?
- What are the symptoms of code P0144 ?
- How do you troubleshoot code P0144 ?
- Codes Related to P0144
- Get Help with P0144
- DTC P0144 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 3 (B1S3)
For reference, Bank 1 and Bank 2 refer to which bank of cylinders, left or right if it’s a V configuration, Bank 1 containing Cylinder 1. Inline engines may be divided, Bank 1 being Cylinder 1 & 2 or 1 – 3. Sensor 1 or Sensor 2 refers to the sensor’s position before or after the TWC. Sensor 1 is before the TWC and Sensor 2 is after the TWC. Sensor 3 refers to the 2nd oxygen sensor that is located downstream of the catalytic converter on some V8 and V10 and V12 engines.
Depending on year, make, and model, DTC P0144 may have number of causes. Here are some of the most common.
- P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
- P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
- P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
Reading P0144 on your car
A basic adapter will show you P0144, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
