P0143 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 3, bank 1 -low voltage
Last Updated 2016-07-05
P0143 | Heated oxygen sensor (HO2S) 3, bank 1 -low voltage (Buy Part On Amazon) | Exhaust leak, wiring short to earth, H028, ECM |
What Does Code P0143 Mean?
- DTC P0143 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 3 (B1S3)
For reference, Bank 1 and Bank 2 refer to which bank of cylinders, left or right if it’s a V configuration, Bank 1 containing Cylinder 1. Inline engines may be divided, Bank 1 being Cylinder 1 & 2 or 1 – 3. Sensor 1 or Sensor 2 refers to the sensor’s position before or after the TWC. Sensor 1 is before the TWC and Sensor 2 is after the TWC. Sensor 3 refers to the 2nd oxygen sensor that is located downstream of the catalytic converter on some V8 and V10 and V12 engines.
What are the common causes of code P0143 ?
Depending on year, make, and model, DTC P0143 may have number of causes. Here are some of the most common.
What are the symptoms of code P0143 ?
How do you troubleshoot code P0143 ?
Codes Related to P0143
- P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
- P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
- P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
