P0141 – Heated oxygen sensor (HO2S) 2, bank 1 heater control circuit malfunction
Last Updated 2015-11-25
P0141 | Heated oxygen sensor (HO2S) 2, bank 1 heater control circuit malfunction | Wiring, H025, ECM |
What Does Code P0141 Mean?
Code P0141 stands for HO2S heater Performance Bank 1 Sensor 2. This indicates the PCM has detected a problem with heater circuit of the downstream oxygen sensor. Bank 1 refers to the side of the engine that has the #1 cylinder. Bank 2 is the opposite side of the engine. If you’ve got a four-cylinder, there will only be one bank. The related code for the other bank is P0161 HO2S Heater Performance Bank 2 Sensor 2. This indicates the PCM has detected a problem with the bank 2 downstream oxygen sensor heater.
Oxygen sensor diagram
(Courtesy: samarins.com)
What are the common causes of code P0141 ?
To sum things up, the common causes for code P0141 are as follows:
What are the symptoms of code P0141 ?
How do you troubleshoot code P0141 ?
(Courtesy: alldata.com)
(Courtesy: 2carpros.com)
Codes Related to P0141
DTC P0030: HO2S Heater Control Circuit Bank 1 Sensor 1
DTC P0036: HO2S Heater Control Circuit Bank 1 Sensor 2
DTC P0053: HO2S Heater Resistance Circuit Bank 1 Sensor 1
DTC P0054: HO2S Heater Resistance Circuit Bank 1 Sensor 2
DTC P0135: HO2S Heater Performance Bank 1 Sensor 1
DTC P0141: HO2S Heater Performance Bank 1 Sensor 2
DTC P0050: HO2S Heater Control Bank 2 Sensor 1
DTC P0056: HO2S Heater Control Bank 2 Sensor 2
DTC P0059: HO2S Heater Resistance Bank 2 Sensor 1
DTC P0060: HO2S Heater Resistance Bank 2 Sensor 2
DTC P0155: HO2S Heater Performance Bank 2 Sensor 1
DTC P0161: HO2S Heater Performance Bank 2 Sensor 2
BAT Team Discussions for P0141
- 2001 Honda Accord
Are there any other trouble codes besides PO420?Remove the No 13,7.5 Amp fuse for the clock to reset the Pcm and then follow the instructions below.The older Accords,98,99 had troubles with the converters.It may be the newer models like yours have the same trouble. DTC P0420: Catalyst System Effici... - Dodge Intrepid code
We need mileage and engine and year. Any other codes ? What is repair and tune up history? If it is the cat bad they are under federal warranty for 80k or 8 years. But one of the main causes of cat codes is bad tune up or engine miss or running rich. Also sometimes there is a pcm reflash for the pro... - 1999 alero won't start
Thanks Gus; The temp. fix worked. The service code is P0141; what is this? What is the perm. fix ; Passlock mod.? MikeP Gus meant to set the Parking Brake. Once again thanks a bunch. Waiting to hear on code. Great Job guys!!!!!!!! Rick... - Honda 2000 Accord SE 4cyl: P1149
One thing to check on is your warranty. If I am not mistaken, the ECM is covered under the emissions warranty and may still be under warranty. You will need to check with your dealer to confirm that. [b]DTC P1149: [/b] A/F Sensor (Sensor 1) Range/Performance Problem DTC P1165: A/F Sensor (Sensor 1)... - 96 Accord LX Oxygen Sensor - Help
Hello! Sorry for the delayed reply. I went back to AutoZone and the ODBII error is P0141. He printed a picture out for me showing this as Heated Oxygen Sensor Bank 1 Sensor 2. It shows it located directly on the exhaust pipe right before the catalytic converter. I looked and could not find anyt...
Is this supposed to be fix by a mechanical engineer or an Electrical engineer
