P0139 – Heated oxygen sensor (HO2S) / oxgen sensor (O2S) 2, bank 1 -slow response
Last Updated 2016-09-20
P0139 | Heated oxygen sensor (HO2S) 2, bank 1 -slow response (Buy Part On Amazon) | Heating inoperative, wiring, H028 |
What Does Code P0139 Mean?
OBD II fault code P0139 is defined as “Oxygen Sensor Slow Reponse (Bank I Sensor 2)”, and is set when the PCM (Powertrain Control Module) detects that Heated Oxygen Sensor #2 is not operating within predefined parameters.Note that “Slow Response” in the definition refers to the time taken by the sensor to react to changes in the composition of the exhaust gas. In this definition, “Bank 1” refers to the bank of cylinders that contains cylinder #1, while “Sensor #2” refers to the oxygen sensor that is located downstream, or after the catalytic converter.
The distinction between the functions of the oxygen sensors located before and after the catalytic converter(s) is an important one. While sensor #1 (located before the converter) is primarily concerned with analyzing the exhaust stream to detect changes in the level of oxygen in the gas so that changes to short-term fuel trim can be made by the PCM, the #2 sensor (located after the converter), is concerned with monitoring the function of the catalytic converter.
In practical terms, a fully functional #2 oxygen sensor fulfills a diagnostic role, and once it has entered closed loop operation, which is when its heating element has reached its proper operating temperature of around 316 °C (600 °F), it should deliver a relatively steady signal voltage of between 0.5 volt, and 0.7 volt. Major fluctuations in this signal voltage indicate a defective catalytic converter, since changes in the composition if the exhaust gas are not being absorbed, or “damped out” by the converter.
Conversely, signal voltages from the #2 sensor that fluctuate from much below about 0.5 volt to much above 0.7 volt, or a signal voltage that remains static without changing at all indicate a defective sensor, or a fault in the sensor’s control and/or signal circuit.
What are the common causes of code P0139 ?
Common causes of code P0139 are much the same across all applications, and could include the following-
- Open circuits
- Blown fuses (where applicable)
- Defective oxygen sensors
- Heavily fouled or contaminated oxygen sensors
- PCM failure is a rare event, and the fault must be sought elsewhere before any controller is replaced
What are the symptoms of code P0139 ?
- Stored trouble code, which may or may not be accompanied by a warning light, since some applications require multiple fault cycles to occur before a warning light is triggered. In these cases, the code may be stored as a “pending” code.
- Rich running conditions may be present. In extreme cases, black smoke from the tail pipe may be present.
- Reduced fuel economy may be present.
- Lean running conditions may be present.
- Engine may hesitate or stumble upon acceleration.
- Rough idling may be present.
How do you troubleshoot code P0139 ?
NOTE #1: Diagnosing code P0139 requires that the engine be in perfect running condition. The fuel/air ratio must be delivered at the ideal 14.7: 1 ratio, there must be no misfiring codes present, and there must be no vacuum or exhaust leaks present. If any air/fuel metering codes are present along with P0139, these codes must be resolved in the order in which they were stored before attempting a diagnosis of this code. Failure to do this will almost certainly result in a misdiagnosis and many hours of wasted diagnostic time.
NOTE: Applications that are known for their high oil consumption rates such as BMW, Audi, VW, and Mercedes-Benz products, among others, can cause oil fouling of the upstream oxygen sensor and damage to the catalytic converter, which in turn, can cause the downstream (#2) sensor to produce misleading readings. On these applications, removal and inspection of affected oxygen sensors should be a first step in diagnosing code P0139.
Codes Related to P0139
- P0136 – Relates to “O2 Sensor Circuit (Bank 1 Sensor 2)”
- P0137 – Relates to “O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)”
- P0138 – Relates to “O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)”
- P0139 – Relates to “O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)”
- P0141– Relates to “O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)”
